How far do your windows 'roll' down when you open the door?
Old Jun 11, 2009 | 02:33 PM
2fasst's Avatar
2fasst
Default How far do your windows 'roll' down when you open the door?
Some help pls guys. How far do your windows move down when you open your doors? My driver's side window goes down atleast 1/2 an inch while my passenger window barely goes down 3mm???
Is this normal?
Old Jun 11, 2009 | 03:02 PM
DavesZ#3's Avatar
DavesZ#3
Neither is "officially" normal. The FSM says 10mm but from what I've seen, it's more like 3-4 mm.
Old Jun 11, 2009 | 03:12 PM
Done Deal DR's Avatar
Done Deal DR
About 1cm or less on mine.
Old Jun 11, 2009 | 03:30 PM
bluelineshooter's Avatar
bluelineshooter
Mine's just a weee bit, but enough. I'd think as long as it goes back up, there shouldn't be a problem, right? But very interesting observation.
Old Jun 11, 2009 | 03:38 PM
2fasst's Avatar
2fasst
Only reason why I noticed is because I had my windows tinted. They both moved about 2 mm a few weeks ago. Now one side is 1/2 an inch while the over is still 2-3mm.
Old Jun 11, 2009 | 05:08 PM
A couple of mm. Just enough to break the rubber seal.
Old Jun 11, 2009 | 05:11 PM
Spork's Avatar
Spork
Close to 1/2 a cm. Clears the seal fine.
Old Jun 11, 2009 | 05:51 PM
2fasst's Avatar
2fasst
seems everybody's different. Mine used to be only about 2mm on both sides. It's 1/2 inch on the driver's door now but when i try to wiggle it, it's not loose.
Old Jun 11, 2009 | 06:02 PM
can'tZme's Avatar
can'tZme
My passenger side goes down further than my drivers side. That's all I know...
Old Jun 11, 2009 | 06:12 PM
2fasst's Avatar
2fasst
well, that's some comfort
I've disconnected the battery to reset the computer but didn't help. I tried to wiggle it and it's not loose so it's not mechanical I don't think.
Old Jun 11, 2009 | 11:34 PM
Zerocool's Avatar
Zerocool
Noticed the same thing the other day. I shut my door when i got in and it sounded like the window didnt drop at all. When I got home checked it again and it barely moves, but enough to clear. When the door is open im also able to push it down manually a little bit more. Havent had any problems since
Old Jun 12, 2009 | 12:31 AM
Kwame's Avatar
Kwame
There is a window reset procedure outlined in the Factory service manual (which I don't happen to have on this computer) that might help to correct anything that might have been altered by your window tinter.
Old Jun 12, 2009 | 08:34 AM
CancerJCCz's Avatar
CancerJCCz
Or if you look at the DIY on window motor replacement I believe it is in there as well. G/L OP.
Old Jun 12, 2009 | 09:52 AM
DemitriHKS's Avatar
DemitriHKS
mine stopped working lol. Maybe it's better that way....haha
Old Jun 12, 2009 | 10:19 AM
spdtckts's Avatar
spdtckts
mine used to go down like half way on the driver side then none on the passenger side and it turned out that my autoroller was in the process of dieing a horrible death so i replaced them.
Old Jun 12, 2009 | 07:36 PM
atom12's Avatar
atom12
as much problems that i had with mine . i wish i could switch over to crank windows
Old Jun 12, 2009 | 08:04 PM
2fasst's Avatar
2fasst
you say that but you don't. I remember the olden days when i had to crank down my windows to pay toll or parking, it sucks. or if you tried to talk to someone standing by the passenger door and you have to lean over and crank down the window.
Old Jun 12, 2009 | 08:34 PM
SirSpeedyZ's Avatar
SirSpeedyZ
couple of mm, try resetting the window motor, that fixed an issue of mine
Old Jun 17, 2009 | 08:50 PM
JLedesma90's Avatar
JLedesma90
i second that motion! i was iinto the honda thing...no more rollup windows ever anymore...i used to think lightwieght over comfort...god i missed my a/c, powersteering, and electrical windows! lol
Obadabot
Jun 18, 2023 11:31 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
