tired of searching...need help
Old Jun 13, 2009 | 03:40 PM
JFAIR's Avatar
JFAIR
Default tired of searching...need help
im looking for the diy 03-05 blacked out head lights tread. thanks
Old Jun 13, 2009 | 05:04 PM
lbz's Avatar
lbz
I have a thread for taking the headlights apart for replacing the amber strips with clear. This would get you inside the housing and pulling the chrome covered pieces out.
From there you could paint those flat black and re-assemble.
Is that what you had in mind for blacking out?
If so, click below and just disregard the steps related to the clear diffuser strips unless you want to replace those.
https://my350z.com/forum/body-interi...-part-1-a.html
Also, I found these in the DIY section:
https://my350z.com/forum/body-interi...light-mod.html
https://my350z.com/forum/body-interi...eadlights.html
https://my350z.com/forum/body-interi...k-housing.html
Old Jun 13, 2009 | 05:21 PM
JFAIR's Avatar
JFAIR
thanks ibz, but i'm trying to figure out what pieces come apart on the interior of the 03 headligths. ie the area around the turn signal bulb and the rest of the housing.
Old Jun 13, 2009 | 05:34 PM
lbz's Avatar
lbz
Looks like the second of the 3 links I grouped together shows what comes apart in the 06.
From what I can tell, the only mechanical difference in that from the 03 - 05 models is the LED module that replaced the amber diffuser strip.
Popping the amber strip out would be the same as removing the LED module.
It's not all that complex. Just have to handle the main bulb with caution, not getting any finger prints on the actual bulb, handling only by the base, and then making sure you get a good seal when you put it back together again.
And make sure you remove all parts before baking.
Old Jun 13, 2009 | 06:05 PM
JFAIR's Avatar
JFAIR
thanks for your help
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
