Painted Door Handles?
Old Jun 21, 2009 | 11:59 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Default Painted Door Handles?
I have seen a few Zs with them done and jw how they did it. Searched Painted door handles and most of the threads are 3-5 years old. Any help?
Old Jun 22, 2009 | 12:15 AM
shvd64cdy's Avatar
shvd64cdy
what do you need help with on it? it's pretty straight forward. are you asking how to remove/install them?
Old Jun 22, 2009 | 12:16 AM
G3O's Avatar
G3O
easy just mask out the serroundings ,and prep and spray
Old Jun 22, 2009 | 12:36 AM
2004Black350z
Exhaust Whore
damn i thought it would be harder then that. But yea im asking what paint needs to be used? how to u take them off? Maybe i should just go to a dealership and have them do it so if it fcks up it wont be my fault
Old Jun 22, 2009 | 01:07 AM
alltech_magoo's Avatar
alltech_magoo
remove them yourself fairly easy to do, just remember how everything goes for when you put them back on.
Old Jun 22, 2009 | 01:33 AM
Mike@Blackline's Avatar
Mike@Blackline
for removal, do you have to take the inside door panel off? or can the 'pull' part of the handle be taken off easily, which would expose the back and underside of the handle for easy paint
Old Jun 22, 2009 | 01:45 AM
2004Black350z
Exhaust Whore
ok so what about paint clear coat etc? What do u use
Old Jun 22, 2009 | 01:55 AM
Mike@Blackline
any kind of clear coat would work, though you're probably going to want to find something that has a high hardening property, maybe even go with enamel since it is a high contact area and you dont want your work to wear off
maybe this? http://www.hobbylinc.com/htm/szx/szx90109.htm
or just some standard automotive clearcoat, but again the high touch area may not hold up over the years with standard auto clear coat.
most shops will do it for you for roughly 65 dollars a handle. i have a place in raleigh that does OUTSTANDING work at extremely good prices (my brother works there) so if you're ever in raleigh let me know (i live in charlotte but id make a call for you), and a tint shop that has done my last 7 cars so you could kill two birds with one stone in raleigh
Old Jun 22, 2009 | 02:00 AM
2004Black350z
Exhaust Whore
lol at 2 conversations going on 2 diff threads with same people. lol anyways i might take u up on that door handle paint ASAP. Tinting is already done actually like 2 years ago and holding up perfect.
Old Jun 22, 2009 | 02:14 AM
3FIDDYZED's Avatar
3FIDDYZED
Just had mine done, took them to a paint shop as they would have done a better job than me!!
Passanger side off and back on in seconds... Driver side is a different kettle of fish! My advice is to undo the 3 screws, (2 inside behind the rubber gromets and one in the side of the door.) The pull out the door handle slightly and look for the brass door lock.
This is held by one bolt, use a ratchet with a 8 or 10mm socket (cant remember which!) and then leave the lock in the door and remove the handle....
When refitting the handle locate the leaver arm and then refit the lock...
I couldnt find a "how too" on this but I may do one soon with pics!....
Old Jun 22, 2009 | 02:28 AM
Mike@Blackline
haha you right
3FIDDYZED so for both sides you have to take door panels off? I did that once on my Z and never ever got that door panel back on right, so that sccurrs me. stupid clips
Old Jun 22, 2009 | 07:49 AM
ParanoidAndroid's Avatar
ParanoidAndroid
take it to a body shop and ask them to do them in a ceramic clear coat, since the door handles are a high traffic area they are prone to scratches. the standox ceramic clear coat is more chip/scratch resistance. The Standox clear coat will even fix minor scratches by itself with the heat of the sun.
Old Jun 22, 2009 | 11:54 AM
RoTors350Z's Avatar
RoTors350Z
Or after they get painted have your handles clear bra'd
Old Jun 22, 2009 | 04:21 PM
epidemic007's Avatar
epidemic007
i wanna have his done too, whats the average price to have this done professionally?
Old Jun 22, 2009 | 04:47 PM
BlueZ33's Avatar
BlueZ33
for those of you asking if you will be needing to take your door panels off to do this. the answer is no you dont, and ive been wanting to do this but havent had the ***** to tape them off and figure out what paint i want to use
Old Jun 22, 2009 | 04:57 PM
ZKansasZ's Avatar
ZKansasZ
Im confused. You say that you dont have the ***** to tape the handle to paint but you tell people that they dont have to take them off to paint ?
No matter how good you think you are, just take those handles off to paint!
It only takes about 5-10 mins for both of them anyway.
Old Jun 22, 2009 | 05:06 PM
Waiz's Avatar
Waiz
I traded another member for mine back in October of last year. They are still holding up very well, since I gave up wearing brass knuckels. LOL
I would follow the directions given by 3Fiddyzed, just make sure your tools have a good magnetic cling when removing the nuts, otherwise if they fall in between the door you need to remove the entire panel.
Old Jun 22, 2009 | 06:25 PM
fatlace_ak21's Avatar
fatlace_ak21
I was gonna do this, but then thought a silver door handle blends better with my silver paint versus a black handle. Looks good on the pic above though^
Old Jun 23, 2009 | 02:09 AM
3FIDDYZED's Avatar
3FIDDYZED
haha you right
Nope, you do not have to remove any of the interior panels to do this mod, just the door handles!
Old Jun 23, 2009 | 02:14 AM
3FIDDYZED's Avatar
3FIDDYZED
Oh and if you do paint the handles on the door you will find you wont get the paint in the bit where your fingers go or you will be doing too much taping up...
Seriously, just drop the 2 bolts out of the inside of the passanger door (behind the 2 grommets next to the door card, behind where the handle is located.) and take the handle off and have a look...
When carefully refitting, drop the leaver arm in first so it locates into the blue plastic cup in the door and then tighten up the 2 bolts and test the handle to make sure it opens... Best done with the window down so if it hasnt located you can just use the interior handle to open and then try and relotate the arm!
