Orange lip!!!???
Old Jul 10, 2009 | 12:35 PM
Dark8lue's Avatar
Dark8lue
Default Orange lip!!!???
I think a flat blac or gloss black wheel with an orange lip would look amazing on my 07 solar orange z the problem is finding one. ive seen blue, red, and yellow lips. Does anyone know where i can find such a wheel/ if so send a link or pics of suggestions
Old Jul 10, 2009 | 12:42 PM
ChaserAero's Avatar
ChaserAero
Vendor - Former Vendor
I think that would look awesome, maybe try a local body shop to get it color matched?
Old Jul 10, 2009 | 12:44 PM
Done Deal DR's Avatar
Done Deal DR
No wheel manufacturers will have anything even remotely close to Solar Orange in their wheel line, a bodyshop will be able to spray them to an almost perfect or perfect match.
Old Jul 10, 2009 | 12:48 PM
0jiggy0's Avatar
0jiggy0
GL, post pics if it happens.
Being unique ftw.
Old Jul 10, 2009 | 12:59 PM
Dark8lue's Avatar
Dark8lue
i will def post pics of the wheel but it seems like nobody makes them so they will be custom made..check this out http://www.whudditdew.com/AXIS.html.
Old Jul 10, 2009 | 01:03 PM
Dark8lue's Avatar
Dark8lue
they are called "axis super hiro" w/ orange pinstripe now just hope its not f$#%ing expensive as hell
Old Jul 10, 2009 | 01:19 PM
Chebosto's Avatar
Chebosto
pin strip it first. then decide if you like it or not.
i pin strip'd my RE30s with Orange Sticker...
Old Jul 10, 2009 | 01:43 PM
Forum rule #12:
Always complain about wheels that you cannot find rather than select from the hundreds available.
Old Jul 10, 2009 | 02:11 PM
PikesPeakZ's Avatar
PikesPeakZ
Originally Posted by davidv
Forum rule #12:
Always with the helpful hints
Old Jul 10, 2009 | 02:12 PM
magicballer2001's Avatar
magicballer2001
http://www.axiswheels.com/wheels.php?id=super_hiro
idk how close the orange is, but you can get the 19s 8.5f and 9.5 r for around 1500
Old Jul 10, 2009 | 02:14 PM
magicballer2001
Old Jul 10, 2009 | 03:46 PM
Spork's Avatar
Spork
Get matte Volk Time Attacks and pinstripe them orange.
Old Jul 14, 2009 | 08:54 PM
Armitage's Avatar
Armitage
Agreed it would look hot, but in most cases its a custom job.
That looks sick! I guess its not that difficult pinstriping a round shape instead of a flat surface?
Old Jul 16, 2009 | 12:53 PM
Chebosto's Avatar
Chebosto
Nope. especially not vinyl. its stretches so if you did your circumference calculations correctly (and add 1/2" for overlap to cut down so it sticks better) for the size wheel you want, just put down one side and go slow and slightly stretch and stick as you go around. with the RE30s there is a mini step lip which i followed that kept the lines fairly straight-
wash the wheel with dishsoap to remove all wheel grime and dust, dry off, use alcohol pad, let dry, then stick on...
should take like, 5 min a wheel if you go slow- if you mess up, just get another strip!
doublej32
Wheels Tires
Sep 25, 2015 05:05 PM
Scherer
Sep 11, 2015 12:30 PM
