2006 headlights in a 2004 both HID, DRL question
Old Aug 11, 2009 | 12:59 PM
XERMAN2001's Avatar
XERMAN2001
Default 2006 headlights in a 2004 both HID, DRL question
i am in Canada i have Day time running lights. In my 2004 my DRL are my high beam bulb at a lower voltage making them light up dimly during the day while the car is running.
As far as i understand on the 2006 and up cars here in Canada use parking light below the projector as a DRL.
i have search and now that the 2006 lights are a plug and play in my 04, and that the blue wire may have to be cut to avoid the yellow bulb from being on all of the time.
When i swap to 2006 lights my high beam wire will power the small motor moving the projector flap up and giving more light rather then powering a halogen bulb as it does now.
My question is, when my low beams are on the motor will not be powered, when the high beam is on the motor will be powered. When my headlights are off the wire would get power as a lower voltage, and send that to the motor would it not. what would happen? would it be harmful?
thanks
Kevin
Old Aug 12, 2009 | 06:47 AM
XXL's Avatar
XXL
no idea? on a side note...where are your buying your 06 headlights from and how much?
Old Aug 12, 2009 | 07:57 AM
XERMAN2001's Avatar
XERMAN2001
i found a set that was replaced under warranty because of a leak. i will have to use my ballast bulbs and wires or buy some. so i just bought the housings which will be resealed when i paint them.
Got a smoking deal, $100 cnd for both
Old Aug 12, 2009 | 10:39 PM
XERMAN2001's Avatar
XERMAN2001
no one?
Old Aug 29, 2009 | 05:23 PM
XERMAN2001's Avatar
XERMAN2001
bump
Old Mar 9, 2010 | 07:04 PM
XERMAN2001's Avatar
XERMAN2001
anyone?
Old Mar 21, 2010 | 06:41 PM
XERMAN2001's Avatar
XERMAN2001
liqalu04
Jan 2, 2022 12:58 PM
Pleask
Dec 21, 2021 03:17 PM
Dsowe
Feb 17, 2021 10:38 AM
