Bulb in Headlight - Stupid question..
Old Aug 19, 2009 | 08:13 PM
bolton350z's Avatar
bolton350z
Default Bulb in Headlight - Stupid question..
I know this is a stupid question, but I just installed the 6K hids ( I have a base so wanted the upgrade ), but there is a small bulb that comes in from the side in the headlight im not sure what it is, when the headlights are on it is on and also when its just the running lights you could call it. It is yellow and kind of ruins the effect of the nice white headlights in there now, So i was wondering what is that bulb called, the size, or any websites or stores that would sell a bright white set of bulbs for it.
thanks guys! Justin
Old Aug 19, 2009 | 08:15 PM
Motormouth's Avatar
Motormouth
yes it is a lightbulb. I am 85% sure of that. otherwise one of your litebrite pegs got misplaced.
Old Aug 19, 2009 | 08:21 PM
bolton350z's Avatar
bolton350z
id appreciate some real help. thanks.
Old Aug 19, 2009 | 08:23 PM
Motormouth's Avatar
Motormouth
kidding aside, you were right. and yes, they sell replacement bulbs to 'clear' it out. so you will have no problem getting rid of that pesky color.
note: it is highly illegal to remove the amber colored bulb I believe, so you might want to check that out. I live in PA is why I mention it. clearing your side markers is also illegal I believe.
Old Aug 19, 2009 | 08:58 PM
bolton350z's Avatar
bolton350z
see this is why im confused though. in the headlight there is the projector, and the reflector lights up orange, but there is a small bulb that comes in from the side into the headlight with no cover or anything and its a yellowish color. Its not amber its just the OEM "white" that nasty yellowish color. Do you know what this bulb is called, the size of it or where i could possibly get a replacement. Maybe a link to a website?
Old Aug 19, 2009 | 09:07 PM
bolton350z's Avatar
bolton350z
Low Beam Headlight Bulb Size: H7
High Beam Headlamp Light Bulb Size: H1
Parking Light Bulb Size: 168
Front Turn Signal Light Bulb Size: 992 (7440A)
Rear Turn Signal Light Bulb Size: 992 (7440A)
Tail Light Bulb Size: 7443
Stop Light Bulb Size: 7443
High Mount Stop Light Bulb Size: Assembly
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 7440
Front Side Marker Light Bulb Size: 168
Rear Sidemarker Light Bulb Size: 168
Map Light Bulb Size: DE3175
Trunk/Cargo Area Light Bulb Size: 168
which one of these is it? if you look directly into it on the drivers side for example, notice this is a 2003, this bulb is sticking in from the right side.
Old Aug 19, 2009 | 09:22 PM
Motormouth's Avatar
Motormouth
please point to where the man touched you:
Old Aug 19, 2009 | 09:28 PM
Motormouth's Avatar
Motormouth
and here is a front shot refernce to line this up. describe where in this picture the bulb is you are looking at:
top is turn signal, middle is high beam, bottom is low beam, to the outside bottom bulb is the parking light I believe or 'day time running light'.
Old Aug 19, 2009 | 10:07 PM
bolton350z's Avatar
bolton350z
there it is, the outside bottom bulb. the one to the left. i thought that the projector is the low beam and the bottom is the highbeam. so what part number is that?
Old Aug 19, 2009 | 10:08 PM
bolton350z's Avatar
bolton350z
its like when you turn the headlight switch just one time before you get to the actual low beams coming on, thats the light that lights up.
Old Aug 20, 2009 | 06:03 AM
Motormouth's Avatar
Motormouth
yeah those are daytime running lights or parking lamps. it's illustrated in that diagram and the bulb number is identified. It seems like a standard size so you should be able to find different colors.
I really hate changing lightbulb colors so I can't tell you where to find them, but I would think Pep Boys - that bastion of tuning culture - would be able to help you.
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
hardwood66
Sep 8, 2015 04:31 AM
