EVO-R Concept Z Front LED with Z4 LED first final install.
Originally posted by silverstoneTT
Can someone tell me whether I can use a wire I bought that has one solid copper metal thing with the ones the sidemarkers come with that has a lot of silver threads of metal?
Also, does the black ground wire get wrapped under a bolt on the car or attached to the black wire running to the light, be it the turn signal or parking?
(2) Yes, you can either wrap the wire under a bolt which grounds to the sheet metal, or you can wire to the negative on the parking/signal light. If you choose to wrap it under the bolt please make sure you find a bolt that provides good ground, no paint between the bolt, wire, and sheetmetal.
Hope these helps!
Well, then, so much for Radio shack. The people who work at them know NOTHING. Now I need to go buy more cable. Where does one buy cable with all the little silver threads?
Whats the reason why the single copper one doesnt work?
FINALLY GOT THEM ON. They look great. Definetly suggest everyone look into these. I wired mine to the parking lights and at night they look completely stock (a plus) and just stand out. Loving them
Vendor - Former Vendor
Glad you like them. Here are some more pictures from our Japan vendor.
http://any-s.net/from-z/slide/LED/index_frame.html
who on the forum has the evo sidemarkers or links to threads with pictures of it on peoples cars?
https://my350z.com/forum/showthread....threadid=63232
Oh great, now I have to spend another $5.00 on more wire as well. I bought the copper wire also. I bought it at Radio Shack, and that's all they had. They didn't have any of the multiple silver wire stuff. Great. Yet another reason to include the right length of wire.
I was disappointed in the Z4 L.E.D. kit because it had no alcohol cleaning pads, connectors or enough wire to reach the front of the car. I was also frustrated in the diameter (width) of the 3M sticky tape because when it's attached to the Z it exceeds the emblem's diameter and can easily be seen after it's attached. I'm attempting to attach these units to a 2004 roadster, and I am skeptical they will be secured 'permanently'. I'm concerned that the contour of the body indentation in that area prevents the tape from holding very well, and the thickness of the area between the L.E.D.s and the emblem is very small. I am going to attempt to attach the L.E.D.s directly to the emblem using glue or epoxy, and I'm not sure how I'll attach to the body.
I also feel the instructions could be much better when explaining how to remove the Z emblem. It says to use fishing line or dental floss, but I found a much easier and faster method. Since the inner fender must be removed to wire the L.E.D.s, it's soooo much easier to use a block of wood and firmly but gently push the emblem's pins from the back.
If anyone can explain what I consider a deficiency in the attachment process using the tape, or has better ideas, I'd appriciate more information.
I'll just you guys a sneak preview of the install we did that will be in our upcoming Project ActiveTuning article. By the time of the article, we'll get these painted LeMans Sunset as well. Final comments are great looking product, would definitely recommend more wire be provided, as they definitely need to be extended. I don't trust wire connectors, so I actually soldered the wires up. I also took the wheels off, it just made things soo much easier.
Originally posted by Sins4u33
whats the word on the white led z4 side emblems??? i am looking forward to this ive already got the sidemarkers......gives us an update if u could
Ben
Ben
It would cost alot to make a headlight like that. If one is made at price of $980 would anyone buy? It will have 2 sets of CATZ fog lights and a amber signal light. The headlight cover will be in curved shape like OEM shape. Base will be made of carbon fiber. Still uses OEM parking light wire and signal light.
