Interior Dash
Old Oct 10, 2003 | 09:16 AM
Nothing's Avatar
Nothing
Default Interior Dash
Has anyone been able to change the color of the light-up display for the dash (speedometer, etc.)... is so, got pics? how-to's?
N.
Old Oct 10, 2003 | 10:48 AM
Nothing's Avatar
Nothing
So no one has done this huh?
Old Oct 10, 2003 | 11:59 AM
Dirty Dave's Avatar
Dirty Dave
Havent done it but im def interested if it can be done.
Old Oct 10, 2003 | 02:16 PM
alphared's Avatar
alphared
I think all you need to do is just take it apart and switch the light to get different colors.
Old Oct 10, 2003 | 06:34 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
Im interested too!
Anyone?
Old Oct 20, 2003 | 12:32 PM
Nothing's Avatar
Nothing
*bump*
...not enough traffic to this thread... c'mon, I'm sure some of you crazy light people know how to make this happen!!!
N.
Old Oct 21, 2003 | 08:12 AM
peptidbond's Avatar
peptidbond
Are the bezels colored? They look it to me. The light might be white, but the bezel cut-outs are orange. Not sure, but I am interested.
Old Oct 21, 2003 | 08:29 AM
ares's Avatar
ares
Veteran
I know atleast one person that is looking into doing it, wait and see if he succeeds.
even if he does, this will be a lot of work to do, and noone could really do it for you.
Old Oct 21, 2003 | 02:49 PM
mgl's Avatar
mgl
this process is very time consuming. i did it with my old eclipse. and the process was pretty hard. for the eclipse i have to pull out the entire interior and change the tiny led bulbs behind every part of the bezel and temp. controls. i went from orangy-red to blue-purple, like in vw's. i know it can be done to an rsx as well so i' sure it can be done for the z, but it'll be difficult. this is one project that i will never do again, i don't think its worth the trouble. but if you ever do it, carefully document where all the screws and parts go and post pics when you're done.
Old Oct 21, 2003 | 03:57 PM
DIGItonium's Avatar
DIGItonium
Default Nahh..
Installing the lights are easy versus swapping out gauge faces. Finally! I can post a picture!
I'm currently working on my friend's civic gauge cluster. I only had one Luxeon at the time. I'm currently waiting for a new batch to come in.
Notice the difference in white color. I heard of people using "hiper white" bulbs. They're just blue tinted bulbs. The stock bulbs in this car is covered with a blue membrane to make it look "whiter."
The job? Not cheap. I'm charging him $10 per Luxeon install. For this job, it requires about 6 bulbs to be replaced.
For the 350Z. It IS possible to change the LCD backlighting. As for the gauges, you need to change gauge faces which will require needle removal. I heard it's easier with domestic cars. As for cars like Honda, needle removal is not easy and WILL damage the cluster.
Old Oct 21, 2003 | 06:50 PM
EnthuZiast's Avatar
EnthuZiast
Someone please find a pic!
Old Oct 22, 2003 | 01:48 PM
peptidbond's Avatar
peptidbond
Yup, I thought so. We will have to get someone to make replacement bezels. At least the LCD display can be changed too.
Old Oct 22, 2003 | 06:44 PM
MacGyver's Avatar
MacGyver
Wow, never knew there was interest in this in any car other than the S...
Anyway, if more than just a few of you are truly interested, I might be persuaded to make a kit for the Z. I have continually pushed off my dash upgrade kit for the S as other projects have called for my attention, such as footwell lights and lighted windscreen, like in this thread...
https://my350z.com/forum/showthread....threadid=43780
I had a nice setup all planned out for the S...variable color in different portions of the dash (fully user selectable), color changes as VTEC cams kick in, autmoatic brightness adjustment for daytime/nighttime driving, etc. For more details, check out this link on S2ki
http://forums.s2ki.com/forums/showth...pgrade+cluster
Old Oct 22, 2003 | 07:50 PM
ares's Avatar
ares
Veteran
even in a kit, Id imagine the most you could do is put together the LEDs, the hard part still remains to open the dash and install them all...
Old Oct 22, 2003 | 09:40 PM
DIGItonium's Avatar
DIGItonium
It might be possible to mount the Luxeon directly to the plastic screw-in base. That would be the easy part.
The hard part is looping the wire through the holes. It's hard to describe. Maybe a cheap drawing would help.t
Old Oct 23, 2003 | 07:39 AM
MacGyver's Avatar
MacGyver
True, but I think this is going to be a problem with any type of mod like this. What I would provide would be a board with the LEDs installed and programmed and a pigtail coming off of one side. To install, you would follow the included directions to remove the appropriate dash parts, run and tap the appropriate wires, and put it all back together. Definitely not a project for the timid, but from the types of projects I've seen people doing on this board, it dfoesn't sound like there are too many timid people here. Also, you could always pay a local audio installer to do it for you...I suggest that to people who're too timid to even attempt my lighted windscreen install.
Not an ideal situation, but it's probably the best we can do.
Old Oct 23, 2003 | 10:31 AM
JPizzle's Avatar
JPizzle
macgyver, I'd be interested in changing out my lights...I live relatively close to you, how much would you charge?
Old Oct 23, 2003 | 11:38 AM
MacGyver's Avatar
MacGyver
Well, there's no board yet. I'm not interested in spending time taking apart a dash just to replace a few bulbs, I'm talking about a complete solution that will offer more functionality than just a bulb swap would allow. For more info on what I'm talking about, see here...
http://forums.s2ki.com/forums/showth...luster+upgrade
I didn't realize there would be interest in other vehicles since the S uses the LCD and lights in a more complete fashion than most. I don't spend much time around other cars, so I wouldn't have a clue if another vehicle existed that would benefit...if one exists, like the Z, I could be tempted to push the production schedule up a bit.
Old Oct 23, 2003 | 11:44 AM
JPizzle's Avatar
JPizzle
I can be a test car
Old Oct 23, 2003 | 12:40 PM
DIGItonium's Avatar
DIGItonium
I know this is hard to ask, but it would be interesting to pull the clusters out of a wrecked Z and attempt to dissect it.
It's about $800 for a new cluster. :-/
I won't be the one replacing the gauge faces though. I'll send it off to a professional who can make the faces and install them.
I'll be the one attempting to change out the lights.
Just a thought....
