Headlight lens available seperately?
Old Oct 4, 2009 | 02:37 PM
Aust350z's Avatar
Aust350z
Question Headlight lens available seperately?
I've done some searching trying to determine if the front lens of the headlight can be replaced or if the whole assembly needs to be repalced. Can't seem to get an answer.
I have some deep scratches that will be an expensive polish to fix (and still not 100%) which will cost as much as a new assembly.
Hoping someone here might able to help.
Old Oct 4, 2009 | 02:39 PM
JZurita's Avatar
JZurita
no
Old Oct 4, 2009 | 02:46 PM
Aust350z's Avatar
Aust350z
Thanks for the quick reply JZurita.
It's what I thought too
If I found a second-hand assembly can you re-use the lens from that one though?
Old Oct 4, 2009 | 05:40 PM
jimpactmfsc's Avatar
jimpactmfsc
i think cincity sells replacement lenses bro but they are pricey
Old Oct 4, 2009 | 06:27 PM
You can look at the parts diagram and see that the headlight has sub-components. But the part numbers are deceiving. I have visited my Nissan dealer and told “We can only get the next higher assembly.” Good luck.
Old Oct 4, 2009 | 06:33 PM
calin's Avatar
calin
They do but I highly discourage anyone from spending any money with them. Unless you want to get ripped off and wait for @#$%ing months to get your stuff
Old Oct 4, 2009 | 10:48 PM
Aust350z's Avatar
Aust350z
Looked around and got some part numbers and called my stealership. The lens is AU$70 more than the whole assembly...
Might try some places in the US and see how I go.
Thanks for the replies guys. Much appreciate your help.
Old Oct 5, 2009 | 04:40 AM
raycs7's Avatar
raycs7
If you get a used light with the rear housing damaged, you can switch them out.
Just remember to apply some new sealant on reassembly..
Old Oct 5, 2009 | 07:01 AM
Guilty1s's Avatar
Guilty1s
ebay.... $100. Buy an aftermarket light. The lenses are perfect fit, perfect quality, and perfectly clear like new. It has worked for me more then once. If your interested, pm me and i will find the exact one i got mine from.
Old Oct 6, 2009 | 04:12 AM
boosted99gst's Avatar
boosted99gst
Do what i did before you consider spending any more money than you might actually have to. Go to your local auto parts store (we have autozone) and buy the headlight restoration kit from 3M. It's a 4 stage kit that is used with a drill. I was skeptical of it, but figured before I dropped big coin on a set of replacement lights or lenses, I'd try it for $20. My light's were pretty bad before the kit, close to new after I was done. If you're still not happy with the lights after the kit..you're only out $20, make your decision on what to do then. Spending $20 on the kit, saved me from contacting CinCity and purchasing a set of lenses from them. Good luck.
Old Oct 6, 2009 | 04:38 AM
Jay'Z's Avatar
Jay'Z
Id try this.........
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
