Interior Help!
I have a 04.5 Black on Black my center console and driver door switch panel have some scratches i wanted to repaint them but cannot figure out exactly what color it would be to match the rest of the interior pieces? Does anyone know?
Should the pieces on the center console with that dimple pattern not be sanded maybe steel wool scrubbed? and maybe a paint adhesive instead of a primer? to not fill in the pattern?
Duplicolor has a clear adhesion promotor, I used that and the paint has stayed on really well. I would recommend against any abrasive techniques that would be more intense than polishing compound and water.
True those parts scratch very easily i just finished the driver door switch panel with the duplicolor flat black looks perfect. After wet sanding out the scratches till the piece was smoothe layed 4 coats, once dried polishing compound and then armorall to seal it. looks identicle to other switch panel color! will post some pics soon.
Tochigi_236
Sep 27, 2015 03:40 PM
