Any way to fix scratches on plastic headlights?
Old Oct 16, 2003 | 02:57 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
Default Any way to fix scratches on plastic headlights?
It looks as though something has rubbed up against my headlights causing a fat long scratch. Is there any way to change just the plastic or take the scratch out.
Old Oct 16, 2003 | 03:17 PM
keiffer953's Avatar
keiffer953
Toothpaste may buff it out. It's a fine polish :-)
Old Oct 16, 2003 | 06:50 PM
Vash's Avatar
Vash
You might use a 2000 grit sand paper to sand it 1st. If is the scratch is really deep, you may want to use a 1500 grit then use 2000 grit sand papper. At the end use rubbing Compound to polish it. It should be gone.
Old Oct 17, 2003 | 07:11 AM
junglist350Z's Avatar
junglist350Z
there is plastic polish stuff that you can get that helps sometimes, but yeah rubbing compound and toothpaste can work as well.
Old Oct 17, 2003 | 08:23 AM
old_s13's Avatar
old_s13
what flavor? i prefer aqua fresh since it has the triple color barrier which gives added protection AND a refreshing taste!
Old Oct 17, 2003 | 12:18 PM
keiffer953's Avatar
keiffer953
Well you need not worry about Flouride...Not an issue in this case :-)
Old Oct 17, 2003 | 01:01 PM
MrGraphics's Avatar
MrGraphics
Plastic Polish and some elbow greese:
http://www.tapplastics.com/shop/product.php?pid=113&
Old Oct 17, 2003 | 04:52 PM
AndyB's Avatar
AndyB
Default Plastic polish
I wouldn't use toothpaste since the grit size varies by brand.
The plastic polish you can buy at a good auto parts or hardware store is much more predictable and easy to use.
Old Oct 17, 2003 | 06:15 PM
Ralphus's Avatar
Ralphus
Look at Griot's garage, the sell great glass and plastic poishes.
Old Oct 18, 2003 | 01:38 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
thanks everyone! i'll try some of these out when i get my car back from the dealer
Uriyo_
Sep 8, 2021 08:46 AM
Rev_Night
Nov 7, 2020 06:00 PM
JGee450
Sep 30, 2015 04:32 AM
