Do-Luck Widebody Question
I really like the Do-Luck widefenders and was wandering if anyone knows if they are compatible with other front, rear,and sides. I've never seen them with anything but the whole kit. Nothing wrong with the whole kit and I know fabrication will probably be involved to make anything else work but I'm curious about what it would look like
Huh... .I was under the impression that the Do-Luck wide fenders (+10mm)
only worked with the do-luck wide front end. Are you guys sure?
Obviously anything can work if you have enough T/M!
The Do luck will fit with any other non widebody kit. b/c they really are not a true widebody. Fender is +10mm that is less then 1/2" wider and rear are over quarter panel and dont really do anything unless u cut your quarter panel, witch then the overlay will buy you 1/2" if that. More like fender flares
