Just bought a Seibon Hatch and HAVING PROBLEMS!!!
Old Dec 4, 2009 | 06:33 AM
reserved's Avatar
reserved
Originally Posted by GeauxLadyZ
+1...
Ive heard you CANNOT swap the glass and you have to get new glass with these hatches.
You should do your homework before you buy parts, though.
"I've heard"........that is precisely the problem!
Often times the info out there is vague (and sometimes even unreliable/incorrect).
I have found this thread helpful so far, so thanks OP!
Old Dec 4, 2009 | 06:42 AM
GeauxLadyZ's Avatar
GeauxLadyZ
An actual body shop told me no, which they had nothing to gain from telling me no because i wasnt getting it done, just inquiring. and a guy with Seibon hatch who had his done said no, so hence i have heard, im not going to state it as fact from 1 body shop and 1 guy, though.
I think it is an "iffy" issue when removing the glass...some shops will recommend replace some will do the swap.
Old Dec 4, 2009 | 07:32 AM
M3to350z's Avatar
M3to350z
i got that window from autoall and it worked out perfect. When It came time to remove the window, I could barely remove it. The 3m tape bonds to the window after a few days.
Old Dec 4, 2009 | 09:07 AM
robbinsj's Avatar
robbinsj
So you used nothign but the 3m tape and it worked? Ever open your windows while going 70mph?
Did you drill holes to release pressure on the glass?
Do you have aluminum straps?
Old Dec 4, 2009 | 09:14 AM
M3to350z's Avatar
M3to350z
In fact it's quite the opposite, the wind pushes down on the glass.
Old Dec 4, 2009 | 09:21 AM
SilverLamboZ's Avatar
SilverLamboZ
anyway someone could post some pics of a cf hatch with the tinted lexan glass kit from autoall.com . . . i'm gona buy it but i just wana make sure it looks good
Old Dec 4, 2009 | 09:34 AM
robbinsj's Avatar
robbinsj
Ok so I am going 80 - 100 mph on I-75 "normal speed for me" and I open my windows. Air rushes in the windows and pulls the lexan down?????
Sure... right....
Then why dont people strap it from the inside with aluminum straps?
Either way I dont care pulls or pushes does the 3m hold or does it need more reinforcment????
Old Dec 4, 2009 | 10:46 AM
INTIMAZY's Avatar
INTIMAZY
I used flat black screws on mine plus the regular glass sealer. No 3m tape came with mine.
This is also not the first time that I heard people say opening the windows at high speeds causes a DROP in cabin pressure and not an increase.
I personally had the car cruisin along at 100-110 (West Virginia roads can be verrry lonely) and did not have any problems with just silicon and screws holding the lexan on. Some people warned me that my hatch may crack but so far nothing. Plus, it would be easy to notice since my hatch is painted.
Old Dec 4, 2009 | 04:35 PM
robbinsj's Avatar
robbinsj
Pics please.
Old Dec 4, 2009 | 05:43 PM
Bigchef66's Avatar
Bigchef66
I have a Mastergrade hatch with glass fitted. Initially I called an auto glass company in FL and purchased a glass from them. They came out out fitted the glass to the hatch before it was shipped to antigua. When the hatch arrived it was without seal, glass company it seems doesn't supply them. However I sourced one from Nissan (Way less than 100 bucks) and had the glass removed by my body shop and refitted with the seal in place. No problems the whole affair (minus shipping and hatch cost) was less than 350 bucks.
Old Dec 5, 2009 | 01:23 AM
350zfun19's Avatar
350zfun19
all of you with the lexan kit please post pics of your set ups!
btw i had my oem glass swapped over with new molding for $140 and they came to my house and did it in my driveway in less than an hour.
Old Dec 5, 2009 | 02:51 AM
duro78's Avatar
duro78
You will regret using lexan. Theres a reason its only used for racing vehicles.
Old Dec 5, 2009 | 09:55 AM
robbinsj's Avatar
robbinsj
nice I will have to check my local glass repair to see if they can swing buy and do mine, you buy the moulding from Nissan or the repair shop?
Old Dec 5, 2009 | 11:37 AM
350zfun19's Avatar
350zfun19
the glass guy had a bunch of rolls of different moldings and I just picked one I liked. It was free.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
