Which aftermarket body is best?
Old Oct 21, 2003 | 11:57 PM
hotpp588's Avatar
hotpp588
Default Which aftermarket body is best?
Hi~ just crush my front bumber and front fander, so think about get aftermaket body kit. please tell me what body you like
Old Oct 22, 2003 | 05:53 AM
kbomb's Avatar
kbomb
Sorry to hear that amn. Is it just ur front bumper and fender?
I would go with Vertex body kit. Its very clean and matches the Z's lines. Im saving up for the sideskirts +rears and thinking of adding a Veilside version 1 front lip.
Maybe RSW...go to body gallery on here or 350zonline.com.
Old Oct 22, 2003 | 07:22 AM
havabooz's Avatar
havabooz
unless you buy the Sarona fender or a custom CF fender you will have to get a stock fender
there are so many front bumpers to chose from....some can get here quicker than others and there is a big price range
how much do you want to spend....more importantly..what do you liek
Old Oct 22, 2003 | 11:28 AM
hotpp588's Avatar
hotpp588
Hi Thank you guys to reply, I am thinking to get Amuse Front Bumper and Amuse Light Weight Wide Front Fenders. What do you think?
Old Oct 22, 2003 | 11:29 AM
hotpp588's Avatar
hotpp588
second
Old Oct 22, 2003 | 11:30 AM
hotpp588's Avatar
hotpp588
Old Oct 22, 2003 | 11:35 AM
hotpp588's Avatar
hotpp588
the boday kiy i want get
Old Oct 22, 2003 | 11:36 AM
hotpp588's Avatar
hotpp588
fander
Old Oct 22, 2003 | 12:53 PM
havabooz's Avatar
havabooz
your bumper and fender can easily be fixed..if you are looking for an excuse to buy a kit then go ahead...but if you really just wanna fix it you can
Old Oct 22, 2003 | 02:01 PM
Ralphus's Avatar
Ralphus
Light weight fenders are a bad idea for the street IMO, if you had them in this accident the damage could be much more severe. Just put a stock fender back on there.
Old Oct 22, 2003 | 02:44 PM
MY350Z.COM's Avatar
The best aftermarket parts IMHO are the urethane ones; I've seen/felt the Stillen kit in person and it's of really high quality and quite flexible. I like it.
Victor
Old Oct 22, 2003 | 03:30 PM
swifty949's Avatar
swifty949
its a matter of personal opinion. Urethane is not neccerarily the best. It's heavy, weather affects it, and it's unrepairable. Every material has it's advantages and disadvantages.
The question is too broad. It's like asking, whats the best tasting soda?
Old Oct 22, 2003 | 07:39 PM
MY350Z.COM's Avatar
urethane is heavy? i think not, i had a stillen spoiler in my hands yesterday, it was fairly light!
Old Oct 22, 2003 | 08:48 PM
Gurp's Avatar
Gurp
sarona body kit
Old Oct 23, 2003 | 08:10 AM
Wedge's Avatar
Wedge
When it comes to weight, fiber glass is much heavier than urethane.
Old Oct 23, 2003 | 08:46 AM
abstrakt's Avatar
abstrakt
Originally posted by Gurp
sarona body kit
poor quality...compare it to cwest...BIG DIFFERENCE in fiber glass. i have both that's why
Old Oct 23, 2003 | 10:06 AM
swifty949's Avatar
swifty949
yah its heavier, thats why the old school race cars and F1 cars used Fiberglass before Honey Comb Carbon Fiber was available.
In fact Urethane just does not sell in Japan due to the weight disadvantage. The Stillen importer for japan, hardly sold anything.
My bumper on my car weights around 5 pounds. In urethane it would be at least 30pounds. With anything there are various grades of material. It's used in showers, boats, airplanes, and even production cars (ie corvette stingray)
The reason Fiberglass has a bad rep in the US is due to the cheap knockoffs. They use very cheap fiberglass and shoot it into a mold with a chopper gun. It's very cheap to make, but very poor and it becomes very uneven, it also becomes thick, heavy, and brittle. Also a lot of "good" copies (whatever that means) take an original part and make a mold off of it. The problem with that is, you cannot make an exact mold off of an existing part for manufacturing. When you make the kit there is shrinking that must be factored in. When you have a unexact mold (not made from the original plug) then you will have warpage.
Carbon fiber is similar to Fiberglass. Although a lot of carbon fiber sold here is nothing more than fiberglass with a carbon fiber layer. The weight is the same as fiberglass, unless you are referring to dry carbon fiber. Dry carbon fiber is baked in an autoclav. It's expensive but oh so light. It has no clear coat, so it requires painting. This is what modern race cars & military airplanes use.
As for Poly Urethane it's basically rubber. It's basically the same material that you coat your tables with, or what your garbage can is made of. Its injected molded, the machine is expensive, but within reach. It has a greater impact resistance than fiberglass, but pound for pound, it's heavier than fiberglass. If the ambient temperature is hot, then the Urethane piece can become deformed, and can actually warp. If it's cold the urethane can become brittle and actually crack. If you do cause a strong enough impact with urethane, you will have a permanent crease that will not go away.
A factory bumper is made of ABS. A very expensive machine that very very few aftermarket companies can afford. The costs of the machine will not warrant the amount of sales for the part. You would have to sell thousands of parts to justify the costs. When in fact aftermarket body ktis are a hit if 100 are sold.
Just some things to consider when shopping for a kit.
Also check out symetry. I've seen genuwine C west side skirts. They were not symetrical. The placement of the vent was off by 10cm.
Fitment, symetry, and build quality is what seperates body kit companies in japan. There is no body kit fits all the criteria. Like i said before each material has it's good and bad points. Just like tuning a car, when you gain in one area, you lose off in another.
Just find the right balance, and see what is important to you.
Old Oct 24, 2003 | 03:45 PM
seanrulz's Avatar
seanrulz
wow, great post swiftly! It was a good study for me. Helped a lot
Old Oct 24, 2003 | 11:03 PM
Wedge's Avatar
Wedge
Thanks for the post swifty.........looks like I was wrong about urethane being lighter than fiberglass. I saw some posts on other forums that totally back up what you said.
Old Aug 19, 2004 | 08:01 AM
J-04blackZ's Avatar
J-04blackZ
I had the same thing happend to me..my fender and my bumber is a little worse...i was wondering if what type of fender are these how much do thay cost and whould they fit on stock side skirts?? If not i was looking in getting the greddy front lip and sides and vizage rear...but first would that fit on stock sides if not what about greddy side skirts...please help my Z needs to get fix asap..
