Passenger window not working properly
Old Mar 4, 2010 | 04:47 AM
Britx's Avatar
Britx
Default Passenger window not working properly
Sometimes won't roll down and if it does roll down it sure as hell won't roll back up unless I beat the hell out of the door panel. There is a streak down the inside of the window about the width of a postage stamp as well. How do I fix this? I'm embarassed as hell.
Old Mar 4, 2010 | 04:52 AM
cdoxp800's Avatar
cdoxp800
Check out
https://my350z.com/forum/maintenance...dow-motor.html
also see the NTB04-089 Window Regulator Motor Reset Procedure
Old Mar 4, 2010 | 05:22 AM
Drop by once each month, and review current maintenance trends. Be an informed 350Z owner.
Old Mar 4, 2010 | 05:52 AM
KornerCarver's Avatar
KornerCarver
I suspect you need to have a new motor installed. You can do it yourself by buying a motor at Autozone or have the dealer put in your new motor.
Old Mar 4, 2010 | 06:25 AM
zerafian's Avatar
zerafian
Buy a refurbished motor from advance discount auto online. I just replaced mine a week ago. The driver side window was doing the same exact thing...I would refrain from beating on the door, just leave it up.
It worked fine after the install. Theres a DIY on the forums on how to do it
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
