seibon ts hood, closing off a vent
Old Mar 24, 2010 | 05:55 AM
Entaille's Avatar
Entaille
Default seibon ts hood, closing off a vent
everyone says that you don't need to worry about the vents on the seibon ts hood, but I've found a couple of people that have had their air filters absolutely soaked in a good drive in the rain.
I have a pop charger and there is one vent that is right above it. I was considering sealing it off as a precautionary measure, but figure water will just collect there and probably be a problem of it's own. has anyone blocked off one of the vents or rerouted where the water would run under the hood? is the rerouting option too much of a pain in the ***, should I just seal it off?
or should I add on to the heat shield of the pop charger and make it more like an oem style air box? I considered just throwing the oem airbox back on but I don't really want to do that.
Old Mar 24, 2010 | 05:57 AM
calin's Avatar
calin
My friend keeps a roll of blue painters tape in his trunk and just tapes up the vents when it rains.
Old Mar 24, 2010 | 06:10 AM
Entaille's Avatar
Entaille
haha man I live in the Seattle area, I would be doing that every other day and you better believe I would forget to do it : )
Old Mar 24, 2010 | 06:12 AM
robbinsj's Avatar
robbinsj
cover the filter not the vent. 8)
Old Mar 24, 2010 | 06:38 AM
zer0cool's Avatar
zer0cool
I also notice that in the rain the belt gets wet causing the alternator to slip for about 15 seconds until it kicks all the water off the belt. Sounds odd but thts what I've come to notice. I have an injen intake routed to the front bumper so I don't have the same problem as u do.
Old Mar 24, 2010 | 11:38 AM
Gibbs's Avatar
Gibbs
Know it all
Just get some plexiglass cut to the opening of the holes
in the hood, and then silicone them to the back of the hood.
Old Mar 24, 2010 | 11:40 AM
Nexx's Avatar
Nexx
moral of the story... dont get a vented hood for a daily driver. vents are suppose to be functional not dress up.
Old Mar 24, 2010 | 12:02 PM
robbinsj's Avatar
robbinsj
Agree to a point, my VIS fusion hood is wide open on all 7 vents and is not a daily driver in any format but my 02 civic Si has a turbo CF hood with a front end vent. Water gets in but only hits the engine cover.
Daily drivers can not have many vents and if there open vents they must be in the right place.
Old Mar 24, 2010 | 12:09 PM
Entaille's Avatar
Entaille
nexx, covering one of the six vents is hardly destroying the functionality, though I do agree it wasn't the best choice for a DD.
Old Mar 25, 2010 | 09:54 PM
nismo_nate's Avatar
nismo_nate
just make a cover for your filter, like the stillen/arc/k&n ones have
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
