Porsche/Audi style LED front corners '08
Old Apr 28, 2010 | 11:51 PM
dcains's Avatar
dcains
Default Porsche/Audi style LED front corners '08
Hi Group:
I know there have been a few threads on illuminating the front corner reflectors, but here's what I've done on my '08. Tried to emulate the new Porsche/Audi style, with 21 white LEDs in clear corners:
I also made an amber set, but I prefer the whites.
Dean
Old Apr 29, 2010 | 12:31 AM
metman1490's Avatar
metman1490
That looks great!
Old Apr 29, 2010 | 12:33 AM
deezz's Avatar
deezz
Very good job. Can't wait to install some LED reflectors.
Old Apr 29, 2010 | 01:33 AM
KingBaby's Avatar
KingBaby
Hardest Setting
well done...
now retrace your steps and bring back a 'how-to'...thanks ok...
Old Apr 29, 2010 | 01:57 AM
User 42426's Avatar
User 42426
yes plz, an easy diy would be great!! car looks slick :]
Old Apr 29, 2010 | 05:52 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Man, i usually hate all the reflector LED mods, but this is the first one i have ever seen that doesnt look rice, it actually looks very well done and professional.
I think the key is the LED's in close proximity to one another, not spaced apart like other corner LED reflectors have.
My hats off to you, good work!
Old Apr 29, 2010 | 06:01 AM
lgear080's Avatar
lgear080
looks good and great photos.
nice execution above all.
Old Apr 29, 2010 | 07:51 AM
arsey51's Avatar
arsey51
Your actually looks good......when I first saw these on Audis, I thought ok, something different, then my opinion changed, too blingy, there ok if its a chick car. Yours doesn't look blingy.....good job.
Old Apr 29, 2010 | 09:00 AM
sry110's Avatar
sry110
Very nice looking! In for the DIY post. Are they on all the time when the lights are on (i.e. wired to the parking light), or did you wire a separate circuit and switch?
Old Apr 29, 2010 | 09:09 AM
gmueip's Avatar
gmueip
Hi Kids!
Great work!
Old Apr 29, 2010 | 01:15 PM
dcains's Avatar
dcains
Thanks for the compliments. This is really a very simple job, with the only difficulties involving the separation of the lens from the reflector base. I used a small jeweler's screwdriver to repeatedly (like 40 times) score the glued seam between the two pieces. This worked better than a blade, because it made a groove wide enough to use a larger jeweler's screwdriver to pry the two pieces apart. I just had to be careful and gradually work my way all around the seam several times until the lens came off, prying a little bit more each time around. Then, I superglued the LED strip to the reflector base, facing forward. Here's my source:
http://www.oznium.com/led-flex-strips
I used the 9.5 inch white LED strip, and carefully trimmed off 3 LED's from the end, which made for a perfect fit inside the reflector. I also had to cut a notch in the lens, to pass the wire through after the two pieces were reglued together. I used superglue for the reflector and lens, and clear silicone sealer around the wiring. It's important to use enough superglue to completely seal the seam, as the lens has to be moisture-tight, but using too much superglue will cause the glue vapors inside the housing to cloud the lens. Also make sure the glue holding the LEDs to the reflector base has dried overnight before reassembling the reflector, for the same reason. Other than that, just pop them into the car, which is a little tougher on the right side, because of the windshield washer fluid bottle. Tap into the parking lights for power, as shown in the other threads.
I don't think this mod is suitable for the pre-'06 cars, as the reflectors aren't as deep and won't allow the LEDs to be facing forward. It's almost as if the later reflectors are designed for this mod. because they're larger, deeper, and have a triangle cross-section.
Finally, here's the LED I used in the parking lights inside the headlight housing:
http://www.superbrightleds.com/cgi-b...LED-WHP9-T.htm
Old Apr 29, 2010 | 05:58 PM
duro78's Avatar
duro78
the whole led thing is slowly but surely reaching neon status but your looks good
Old Apr 29, 2010 | 07:29 PM
seanzhao's Avatar
seanzhao
Wow awsome man !
How did u do that?
Can you teach me howto do it ?
I got same car with you~
Old Apr 29, 2010 | 07:43 PM
seanzhao's Avatar
seanzhao
front park light is same with license plate light ???
Old Apr 29, 2010 | 07:46 PM
stevezcar's Avatar
stevezcar
nice job
Old Apr 29, 2010 | 08:00 PM
robbinsj's Avatar
robbinsj
damn thats hot, any chance some one would sell these??
Old Apr 29, 2010 | 08:26 PM
SatchScream's Avatar
SatchScream
That is fantastic, I'd love to do this.
Old Apr 30, 2010 | 05:18 AM
slow_em2's Avatar
slow_em2
did you wire them to the parking lights or did you wire them to a separate switch?
Old Apr 30, 2010 | 05:38 AM
JEKL's Avatar
JEKL
I completely agree. Normally not my taste either, but it looks like you did a nice quality job.
Old Apr 30, 2010 | 05:48 AM
robbinsj's Avatar
robbinsj
+1 really does look like the porche. I usually dont like this but I would take a set shipped to 33559 if its plug and play.
