Seat Belt Question
Old Apr 29, 2010 | 07:33 AM
ryan93's Avatar
ryan93
Default Seat Belt Question
My 350Z Roadster was in an accident, and the passengers seat belt is locked & needs to be replaced. Does anyone know if the seat belts for the Roadsters & Coupes are the same? I found one for a Coupe, but i want to make sure it'll work before buying it.
I called my local Nissan dealer, even gave them the serial numbers from both cars, but they still couldn't answer my question.
Old Apr 29, 2010 | 09:40 AM
robbinsj's Avatar
robbinsj
from my undestanding they are the same bolt size.
Old Apr 29, 2010 | 09:47 AM
JasonZ-YA's Avatar
JasonZ-YA
unless the driver wasnt wearing a seat belt, both would need to be replaced - even if the drivers side "appears" to be fine...
-J
Old Apr 29, 2010 | 12:09 PM
ryan93's Avatar
ryan93
If that's the case Jason, then i hope the driver wasn't wearing the belt! I bought the car damaged in Florida, so i can't answer that. The drivers belt does appear to be fine though.
The car was hit right on the drivers door. The only 2 airbags that went off in the car were the passengers dash, and the drivers seat. Not sure if that helps determine whether the belt was buckled or not...
Old Apr 29, 2010 | 12:22 PM
JasonZ-YA's Avatar
JasonZ-YA
you may wanna look into replacing both............
back story???...........usually at junk yards the drivers seat belt is cut - from emergency crews pulling out an unconscious/dead body??
any blood in the car?? etc??
-J
Old Apr 29, 2010 | 01:27 PM
ryan93's Avatar
ryan93
It was only a light hit, caught it right square in the middle of the drivers door. Are you asking if either of the belts in it were cut? If so no as i said the drivers one appears to work fine, while the passengers one is locked.
Old May 3, 2010 | 11:54 AM
ryan93's Avatar
ryan93
Anyone know where i might find a second hand belt? They are fairly pricey at the dealer.
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
