Headlight Question
Old May 6, 2010 | 08:30 AM
mike99101's Avatar
mike99101
Default Headlight Question
Quick Question-
Will my OEM HID ballast swap into a OEM non HID headlight Assembly??
My headlight is cracked up and i need to get a new assembly but i was not sure if it would swap..
Thanks
Old May 7, 2010 | 08:01 AM
Bumble Z's Avatar
Bumble Z
no it will require modifications if the problem is the plastic cover just take the same steps you would for blacking out the headlights (the plastic removal part ) and swap the plastic casing
Old May 7, 2010 | 11:35 AM
mike99101's Avatar
mike99101
The entire headlight assembly is gone. The top clear plastic is in shambels and the bottom black housing... well there is no black housing; it fell apart.
So the no hid headlight assembly will not fit the xenon ballast etc...
thanks for the help
Mike
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
