this might be a dumb question but how do i change my brake lights
Old May 5, 2010 | 04:07 PM
myjdmspace's Avatar
myjdmspace
Default this might be a dumb question but how do i change my brake lights
How do you change the brake lights on a 350z?
i just put 77,000 miles on my Z and i have to change my brake lights
Old May 5, 2010 | 04:22 PM
KornerCarver's Avatar
KornerCarver
You unscrew the tail light housings, remove them. Once removed, you can see the light sockets. Remove the socket and replace the lights. Re-install your light housings and you are finished.
Old May 5, 2010 | 06:17 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Open rear hatch. Remove plastic "slugs" on top of taillight. Remove 3 bolts. Pull taillights horizontally to free the two tabs that hold them in the body. Don't pull vertically, you'll break the tabs. Then follow the above instructions.
Old May 6, 2010 | 12:49 PM
myjdmspace's Avatar
myjdmspace
thanks
Old May 6, 2010 | 09:36 PM
Waiz's Avatar
Waiz
Switch to the 2006+ LEDs they make a huge difference.
Old May 7, 2010 | 11:04 AM
ReUhssurance's Avatar
ReUhssurance
Noob question but you can do that with an 03-05 Z? Is it just plugnplay style or more complicated?
Old May 7, 2010 | 01:39 PM
G4nismo's Avatar
G4nismo
yes
Old May 7, 2010 | 01:42 PM
dkmesa350z's Avatar
dkmesa350z
direct swap and they are BRIGHT...just got mine this week.
Old May 7, 2010 | 02:18 PM
TreeFiddyZee
Do WHAAAAT!?
Yep. You have to tape off one wire because it doesn't use it, but that's it.
Miguel Albanez
Oct 17, 2022 10:13 AM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
Vigman
Nov 17, 2015 04:34 AM
rizzla
Sep 29, 2015 03:58 PM
RWDBajan
Sep 17, 2015 04:52 PM
