Need help removing glue from carbon fiber side view mirror covers.
Old May 10, 2010 | 07:22 AM
IrishMike's Avatar
IrishMike
Question Need help removing glue from carbon fiber side view mirror covers.
When I bought my car it came with carbon fiber mirror covers. I finally got around to removing them which was a total pain in the a$$. After removing them I was trying to remove the glue that was left behind which was such a pain that I couldnt even finish.
Anyway, its a black type glue that is pretty thick. Not sure if I need to apply heat to remove this because it was pretty cool out yesterday which didnt help.
Anyone know what I can use to remove this?
Also, dont install these unless you are sure you want to keep them!
Thanks,
Mike
Old May 10, 2010 | 09:07 AM
carlili4190's Avatar
carlili4190
What color is your car? If black just leave it...?
I would say heat(blowdryer) and floss...
Old May 10, 2010 | 09:13 AM
Ronin82's Avatar
Ronin82
Old May 10, 2010 | 12:30 PM
Romanteni's Avatar
Romanteni
heatgun, hair dryer... glue+cold=tough sh*t.
Old May 10, 2010 | 12:32 PM
IrishMike's Avatar
IrishMike
Thanks guys, appreciate it!
-Mike
Old May 10, 2010 | 12:36 PM
MODDEDZ's Avatar
MODDEDZ
Why would you remove CF? Anyway, try Goo Gone or fingernail polish. If all else fails, then a razor blade will do the job, but be careful not to scratch the paint.
Old May 10, 2010 | 01:10 PM
Glue is relitively easy to remove. Glue forms a weak bond, and can be removed by braking down the compound with heat or a petroleum distillate.
Epoxy, on the other hand, is as strong as the original material. Properly applied it is not coming OFF.
Old May 10, 2010 | 01:40 PM
MicroSmurf's Avatar
MicroSmurf
You can remove Epoxy with Epoxy Remover.
Old May 10, 2010 | 02:43 PM
Beast101's Avatar
Beast101
+1 Goo Gone FTW
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
