03 touring passenger seat wont move
Old May 19, 2010 | 12:24 PM
carpediemm's Avatar
carpediemm
Default 03 touring passenger seat wont move
the switch for the passenger seat allows the seat to move forward but not backward... anyone know what the problem could be? or do i have to look into aftermarket seats... any help would be appreciated
Old May 19, 2010 | 12:34 PM
lgear080's Avatar
lgear080
use electrical parts cleaner on your chair switch (from radioshack)
or replace (costs roughly $70) the switch unit.
/thread and pls search next time.
Old May 19, 2010 | 03:33 PM
bldg250z's Avatar
bldg250z
had same problem....... all you need to do is replace the switch!
Old May 19, 2010 | 04:46 PM
carpediemm's Avatar
carpediemm
at the moment, i am not able to reach the two front bolts of the seat because the seat is all the way in the front. so i am not able to simply replace the switch as i would like..
Old May 21, 2010 | 04:32 PM
ReelBigAndy's Avatar
ReelBigAndy
I had/have the opposite problem. Hear me out though...the driver seat moves back but not forward. I haven't tried the cleaner spray yet. After I had some repair done to my bumper, the guy who had moved my seat alllll the way back was able to "jump" the seat switch to get it to move forwards again. I imagine it included juicing the correct prongs in the opened connector with 12v, but I'm not sure. I was able to then move it back to a good spot for me and leave it (no one else drives my car anyway).
Bottom line, a shop that knows what this means might be able to "jump" it for you for a temporary solution.
Old May 22, 2010 | 02:57 PM
dgnage's Avatar
dgnage
I had the same thing happen to my 06 touring. cost 1,000 $ for new motor and rails
Old May 22, 2010 | 03:51 PM
marques1's Avatar
marques1
lol.. Are you sure it wasn't just the switch. Why would you have to get a new motor and rails?
Old May 22, 2010 | 03:55 PM
marques1's Avatar
marques1
The same thing happened to my 03 a long time ago. I tried the electrical spray and it worked temporarily. Just go buy the switch from nissan for $70.00 dollars. Make sure before you unhook the seat switches to disconnect the battery otherwise once you get the seats hooked all back up you will get an engine light and airbag light. Then you will have to go through the ecu resetting procedures so save your self the headaches.
Old May 23, 2010 | 08:01 PM
Carlos8183's Avatar
Carlos8183
I have this same problem with my 04 touring.
I used the radio shack spray it seemed to work for a while.
now I when my seat gets stuck and its too forward I just keep pressing the the switch back and push the seat back and it starts to work again.
maybe you can do it too?
Old Jul 12, 2010 | 01:34 AM
PV350Z's Avatar
PV350Z
old thread...but do u spray on top of the switch or the actual rails??
my drivers seat doesnt tilt forward or back anymore....plz lmk
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
samansharif
Sep 25, 2015 12:31 PM
