How do I get the Z emblems off the side of my car??
Old May 20, 2010 | 05:31 AM
RandyK1's Avatar
RandyK1
Default How do I get the Z emblems off the side of my car??
I just ordered some black chrome Z emblems for the side of my car so I need to get the old ones off. I took the emblems off the back with a blow dryer and floss but the side emblems have the indent and dont want to come off. Any help would be great, I really dont want to mess up my paint. Also whats the best way to get the sticky stuff from under the emblems off? I used Goo Gone on the rear and it took the clear coat off so I had to get that fixed and I dont want to go through that again. Thanks
Old May 20, 2010 | 06:09 AM
J. Dub's Avatar
J. Dub
I used searchMore. The ph balance of this stuff is perfect to use on our paint. It will get that emblem off quickly.
Old May 20, 2010 | 06:13 AM
J. Dub's Avatar
J. Dub
This might also help since your searching powers fail you.
Jack up car and put on jack stands.
Remove front wheels.
Remove inner fender liners.
Press out the Z emblem from behind using the butt end of a screw driver. They are held on by two sided tape and have two posts that stick through the body. Press on these posts.
Remove the two sided tape from the body.
Old May 20, 2010 | 06:25 AM
diablox1's Avatar
diablox1
i just pried them off with my fingers after heating them up with a heat gun for about 30 seconds. they're only held on by the 2-sided tape, which is easily peeled off from the body too once the actual emblem is off.
Old May 20, 2010 | 06:38 AM
JEKL's Avatar
JEKL
I just did the exact same thing with my metallic black Z. You are going to love the look! Anyway, I used some really strong fishing line and broke up the tape on the top, sides and bottom of the emblem. At that point you can just pull it the rest of the way off. Might want to use some type of garden gloves, that line can wear on your hands after a while.
Post up some pics when you get them all on.
Old May 20, 2010 | 07:08 AM
DemitriHKS's Avatar
DemitriHKS
Maybe it depends on the year as well man. I don't know what the first guy is really talking about but on mine it was a little different. They are held on with a glue and there's also 2 prongs that sit on the back of the emblem right across the middle. The prongs are slightly slanted so i'm not sure what way you need to pull up or down. But mine is an 03'
Old May 20, 2010 | 08:22 AM
duro78's Avatar
duro78
is there an indentation under the emblem or is it flat?
Old May 20, 2010 | 08:43 AM
MDHRZ's Avatar
MDHRZ
Old May 20, 2010 | 09:08 AM
3m wol8's Avatar
3m wol8
Originally Posted by MDHRZ
Old May 20, 2010 | 10:19 AM
User 42426's Avatar
User 42426
i used goo gone on my paint and its fine. Thats weird. Anyways, just use the same method, floss and just go at it. Should come off.
Old May 20, 2010 | 01:54 PM
RandyK1's Avatar
RandyK1
So let me get this straight, if I go out to my Z and say some smart *** stuff to the car the emblems will fall right off?? SWEET!!! To every one else Thanks for helping and not being a asshat
Old May 20, 2010 | 03:30 PM
juju's Avatar
juju
OP can you post a pic of the emblems you got?
Old May 20, 2010 | 04:31 PM
RandyK1's Avatar
RandyK1
I cant post a pic because I just ordered them yesterday. The best I can do is the links I ordered them from http://www.thezstore.com/page/TZS/PROD/350z03j/31-1142 and http://www.thezstore.com/page/TZS/PROD/350z03j/31-1139
Old May 20, 2010 | 07:19 PM
adamc's Avatar
adamc
i like the chrome z emblems in the pics that you ordered
please post some pics when you get them on the car i'm curious how the end product will look
Old May 21, 2010 | 04:06 AM
whitelightnin's Avatar
whitelightnin
I believe that would be "an" asshat
P.S. Good Luck
Old May 21, 2010 | 04:55 AM
RandyK1's Avatar
RandyK1
P.S. Good Luck
OOPS. My bad
Old May 21, 2010 | 08:46 AM
J. Dub's Avatar
J. Dub
This doesn't make me happy. Grammar **** is upset.
Old May 21, 2010 | 09:57 AM
JEKL's Avatar
JEKL
Old May 21, 2010 | 10:07 AM
Drewsum's Avatar
Drewsum
Default denatal floss
dental floss worked great on mine, just place it behind the emblem and move back and forth going downward, you just have to rember there are two posts to go around.
Old May 21, 2010 | 01:03 PM
RandyK1's Avatar
RandyK1
I never said that I went to skool
