Nismo V1 Wing
Old May 25, 2010 | 09:55 PM
User 42426's Avatar
User 42426
Default Nismo V1 Wing
Hey guys, do you know how much it would cost to re clear a cf wing? Just the top part of the wing, not the base. A general estimate would be great, thanks.
Old May 25, 2010 | 10:07 PM
User 42426's Avatar
User 42426
oh and its a seibon, not authentic nismo. Just want an estimate like under 50 or 100 or something like that. Thanks.
Old May 25, 2010 | 10:11 PM
Waiz's Avatar
Waiz
You should just give a local bodyshop a call since they will give you an actual estimate.
I'm guessing less than $200 depending on how much prepping would be needed.
Give DTM a call as a feeler and decide from there:
(626) 442-0318‎
Old May 26, 2010 | 12:22 AM
User 42426's Avatar
User 42426
wow damn, 200? Ok, ill give him a call, thanks man.
Old May 26, 2010 | 12:33 AM
User 42426's Avatar
User 42426
Found this in another forum:
ok there is a common misconcetption here. Carbon fiber hoods are not "clear coated". they are just layers upon layers of clear epoxy resin that is built up on top of the carbon fiber.
LINKY
check that link out on how a carbon fiber part is made. notice the part, about halfway down, about the final stages. at no part is there clear coat used in the process. its just layers of clear resin that get you that shine. once the hood starts to get hazy, you could try sanding it down and re-applying resin but that is just a pain in the ***. or you could paint it. or you could go ahead and "re-clear" it with paint, but it wont do anything. just trying to inform you about the composition of a carbon fiber hood.
Since I don't want to paint my cf, would applying resin like what was said above be a good alternative to re-clearing?
Old May 26, 2010 | 12:47 AM
User 42426's Avatar
User 42426
and what is the peanut butter trick???
hardkicks
Sep 20, 2015 12:28 PM
350zrn35
Photoshop
Sep 14, 2015 06:53 PM
Chebosto
May 15, 2003 09:32 PM
Chebosto
Feb 11, 2003 06:36 AM
