Turn Signal Not Indicating On Dash Cluster..HELP
Okay so I have a 2007 Z and I replaced my parking lights with a set of white L.E.D ones and everything works all my lights turn on and everything....
But my indicators that light up when the turn signal is on (little green ones with arrows on gauge cluster) are no longer lighting up. The turn signals are all working when I use them Its just the dash indicator that isn't. I also tried the Hazards and they all light up but the indicators don't. Is there a fuse for this? Thanks
PROBELM SOLVED: Fuse under dash fuse panel by the Dead pedal/Clutch pedal, The middle fuse on the bottom row under the fuse puller
Do your turn signal flash faster than before now that you have installed LEDS? If so you might need resistors: http://www.v-leds.com/BlinkerWarning...95272-1-2.html
happened to me check fuses underneath the steering wheel, near the clutch pedal
that kick panel to the left can be removed to reveal a box of fuses
with the car off with the 350z manual check them, simple replace whats broke...
Okay so I did that and they all checked out, ugh I guess ill remove the bulbs tomorrow and see if putting back the oem bulbs will fix them
Thanks a bunch for the help
