Headlight Issues
Old Jul 9, 2010 | 10:38 AM
RocketCoffin's Avatar
RocketCoffin
Default Headlight Issues
I have 03 350Z with HIDs and my driver side headlight is on the fritz. On occasion it decides to work but typically doesn't. Do I go ahead and diagnose the problem as needing a new bulb or do I need a new connector? And if I do need a new connector where would I go about getting one?
Thanks for your help guys!
Old Jul 9, 2010 | 10:48 AM
NewJoyZ's Avatar
NewJoyZ
If it works sometimes, i would guess and say it is not the bulb. But im no Confucius. I dont know where to get it. Sorry.
Old Jul 9, 2010 | 11:34 AM
vex008's Avatar
vex008
i would guess connector, try a salvage yard near you. might be a couple bucks
Old Jul 9, 2010 | 11:40 AM
Carlos8183's Avatar
Carlos8183
I had sorta this same problem. i tough it was the bulb so I went ahead and bought a new one and still had some problems so I took it with a friend (mechanic) and we discovered it was a simple fuse.
didnt know the z has 3 fuse boxes. lol
Old Jul 9, 2010 | 02:12 PM
You can guess or use a continuity tester. About $10.
Old Jul 9, 2010 | 07:39 PM
RocketCoffin
thanks for the help guys =P hope I get this fixed...I hate driving at night knowing something is wrong with my ride lol
Old Jul 16, 2010 | 02:04 PM
RocketCoffin
how do i go about using that continuity tester? electrical isn't exactly my thing lol
Old Jul 18, 2010 | 08:49 PM
Carlos8183's Avatar
Carlos8183
connect the tester to the battery then check each fuse by touching the point and if the fuse is working the tester will light up if it doesnt it means the fuse needs to be replaced.
the fuses you need to test are behind the battery in a box that pretty well hidden there. took me a long time to find it. lol
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
