Door vent plate removal
Old Aug 15, 2010 | 02:11 PM
stein's Avatar
stein
Default Door vent plate removal
I am re-painting the scratched POS plastic and need to remove this to paint it.
I would like to remove everything that is black plastic around the vent
Anyone know how?
As a side note; All this black rubber paint from the factory is sprayed over a gray enamel paint, the plastic is BLACK to begin with! I don't understand why they even paint it!!!! At least the door handle covers are like this.
<-- prays he doesn't have to remove the door panel!
Old Aug 15, 2010 | 02:53 PM
350ZTheStandard's Avatar
350ZTheStandard
Here is a post I found some time ago, originally posted by VO. You want to start looking at post #6 Hope this helps out.
https://my350z.com/forum/maintenance...dow-motor.html
Old Aug 15, 2010 | 04:24 PM
stein's Avatar
stein
Damn it, I seen that bolt but when I loosened it a bit I didn't feel any give in the vent. I will have to try again I guess.
Thanks
Old Aug 15, 2010 | 04:44 PM
stein's Avatar
stein
ARRRRRRRRRRRRRRRRR!!!!!!!!!!!!!!!!!! I lost the bolt down in the door!!
So I pulled the back some of the door just enough to see behind the vent, it seems I will need to pull the panel off as it has a few screw holding it from the inside, as well as to retrieve the screw I dropped.
Old Aug 15, 2010 | 07:03 PM
oddjobbb's Avatar
oddjobbb
take the door panel off its not that hard, 5 min. tops
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
