LED side marker light(s) replacement
Old Sep 7, 2010 | 06:41 PM
08sleeperz's Avatar
08sleeperz
Default LED side marker light(s) replacement
Hello everyone. I'm slowly starting to mod my z with some small things (details are what makes a car IMO). Anyway, I was wondering how you change the 4 LED side marker bulbs (the ones that go on when you turn the headlights on one click in 07/08 headlights). They currently light up amber but I want to change them to bright white so they blend in with the HIDs a bit better. Needless to say I'm also going to be changing the turn signal bulbs and parking light to match. Any help on this topic would be appreciated. I read a bit and it seems like these lights can be reached from inside the fender. I was just wondering if anyone has actual pictures/knew what size the bulbs were. Thanks.
Old Sep 10, 2010 | 11:12 PM
FliPPER_Z's Avatar
FliPPER_Z
inside the headlight?
bake the headlight at 350 degrees for a few mins....desolder the amber LEDs...install white ones with the proper resistors.... done!!
Old Oct 1, 2010 | 09:47 AM
ColecatZ's Avatar
ColecatZ
OP, you are changing out your turn signals to match your headlights?
/facepalm
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
