headlights
Old Sep 18, 2010 | 09:52 PM
andres benitez's Avatar
andres benitez
Exclamation headlights
Hey guys I was just woundering is condensation normal in headlights?
Old Sep 18, 2010 | 11:04 PM
deezz's Avatar
deezz
Not at all. You probably have a seal issue somewhere. Check the back of your headlights for any damage or loose fittings.
Old Sep 19, 2010 | 04:56 AM
DavesZ#3's Avatar
DavesZ#3
Go to the top of this forum and click on Search This Forum and enter condensation. There are over a hundred threads on the subject.
Old Sep 19, 2010 | 01:47 PM
andres benitez
Ok thanks I had just painted my headlights.I guess I didn't seal it right thanks again
Old Sep 19, 2010 | 06:15 PM
andres benitez
Everything looks good no loose fittings to.is there any way of checking the seal before I put my car together?I really dnt want to pull It apart again.
Old Sep 19, 2010 | 07:06 PM
Tackett's Avatar
Tackett
I ran into the same problem when I painted mine.
Take my advice. You'll avoid a ton of headache if you just rebake them, open them back up, take a tube of silicone and reseal it.
Old Sep 19, 2010 | 07:52 PM
andres benitez
Do you have to take of the old silicone?and if you do what's the best wey to do it?
Old Sep 20, 2010 | 05:59 AM
hwcustoms's Avatar
hwcustoms
No you should not have to remove it if you reheat it. It should liquify when it's warm. Run a new bead of silicone all around the channel with the lens off, press the lights together, insert the screws, smooth out the new silicone with your finger, and fill any gaps. I would recomend you masking tape off the lenses so you don't get silicone on them, and keep a wet rag or alcohol wipe handy for cleanup.
Old Sep 20, 2010 | 09:00 AM
andres benitez
Ok thanks guys for the advice.
Old Sep 20, 2010 | 08:30 PM
andres benitez
Ok I'm sorry I also wanted to ask is the rainbow effect normal when painting headlights? Is it permanant?thanks in advance.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
