vented hood rain drip tray
Old Sep 29, 2010 | 06:17 AM
silver streak's Avatar
silver streak
Default vented hood rain drip tray
is there or is anyone have installed a vented rain drip tray to keep rain/water from getting on any part of the engine? would like to keep inside free of water spots or maybe electrical problems for my 08 coupe. thanks
Old Sep 29, 2010 | 07:26 AM
bmccann101's Avatar
bmccann101
I would assume not.
I doubt you will incurr electrical problems.
Sealing the vents would defeat the purpose.
Get used to cleaning ( or NOT cleaning) the engine more.
Just being honest before anyone else jumped in.
I have a veilside, pressure washer is just fine, just dont blast it right in there. You stand to blow off a vacuum line as the real danger more than anything else. The electrical components are well sealed on this car.
Old Sep 29, 2010 | 08:45 AM
Romanteni's Avatar
Romanteni
My VIS has huge vents right above the intake, and it cake with CF drip tray, but the way its designed it doesn't block any airflow above the intake.
If you have an aftermarket intake, then yeah, if you're worried above electrical stuff- I agree with above, its no problem. You can pressure wash your engine and shouldn't have electric problems. (not recommended ofc). lol.
Old Sep 29, 2010 | 05:48 PM
WSchli1672's Avatar
WSchli1672
I have a bottom tray that I put on when it rains, it's normally cooler anyway during the rain period. Other then that I don't have it on. It (2) came with the hood when I bought it, and I replaced the screws they used with my own to hold it nice and tight. I blow out the vents from the top with my electric Toro Leaf lower ( $29.90 at Home Depot) before I remove the covers, and I get no leaks. I don't like water spots either.
Old Sep 29, 2010 | 06:16 PM
silver streak
thanks for the info and to the point reply. much appreciated, now to find a hood that has some sort of cowling mainly for the look.
Old Sep 30, 2010 | 07:48 PM
WSchli1672's Avatar
WSchli1672
Anytime. I have the CF Seibon Hood. Really does the job. I have the vortech s/c, jwt cams, etc. etc., couldn't be without 400+ hp. And the hood works great. Also I have no problems with heat, as the rain cools everything done anyway.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
PureR3d
Sep 10, 2015 06:23 PM
