Dash problems?
Old Oct 19, 2010 | 06:44 AM
jtgli's Avatar
jtgli
Default Dash problems?
I checked all my fuses inside the cabin and under the hood and I can't seem to find out why my dash does not display the turn signals. To further explain, my turn signals do work but the dash does not display the turn signals that they’re working, same goes for hazard light button, lights are on and working but not showing up inside on the dash. Further my open door beep does not sound when the key is in the ignition, nor does the beep indicating that my headlights are still on. Lastly I am not getting a light on the dash when I put the high beams on. To be clear again everything works on the outside of the car, but no indicatiors or beeps are working on the inside. Anyone know what could be the cause?
Old Oct 19, 2010 | 07:34 AM
Romanteni's Avatar
Romanteni
the beep when door is open you should be thankful for. most annoying piece of **** sound when working on the car with music on haha.
Old Oct 19, 2010 | 09:49 AM
xzotklr's Avatar
xzotklr
Burnt out leds on dash??? Talk to Acree he is a master with the dash lighting. Do a search and you will find him.
Old Oct 19, 2010 | 09:50 AM
6894kevin's Avatar
6894kevin
turn signal solenoid / relay might be bad???
Old Oct 19, 2010 | 10:26 AM
jtgli's Avatar
jtgli
Ive checked all my fuses and relays and everything is ok
Old Oct 19, 2010 | 02:56 PM
redman333's Avatar
redman333
Bulbs bad?
Old Oct 19, 2010 | 03:09 PM
jtgli's Avatar
jtgli
Cant be bulbs since the beep doesnt work either for when the lights are left on or the door is open. Has to something connected on one system?
Old Oct 20, 2010 | 08:41 AM
jtgli's Avatar
jtgli
anyone?
Old Oct 26, 2010 | 09:50 AM
jtgli's Avatar
jtgli
come on guys I need help!
Old Nov 7, 2010 | 12:18 PM
jtgli's Avatar
jtgli
Bump! Anyone!!!????!!!!????
Old Nov 7, 2010 | 12:48 PM
Al Kapwned's Avatar
Al Kapwned
Have you actually checked the fuses using a multimeter? Sometimes when you think a fuse isn't bad it really is. A multimeter would solve that problem real quick.
Old Nov 7, 2010 | 01:24 PM
Ninjadaddy's Avatar
Ninjadaddy
I am currently experiencing the same problem, the dealer diagnosed it as the a/c amplifier. It's located behind the HVAC controls (white box with ribbon cable) $350 +new.
Old Nov 7, 2010 | 02:50 PM
jtgli's Avatar
jtgli
I was hoping it wasnt that box ha. But that does make sense. By any chance do you know what caused yours to go bad?
Old Nov 7, 2010 | 05:37 PM
Ninjadaddy's Avatar
Ninjadaddy
The tech said it was shorting out (arching) internally. A suggestion was made to check all the solder contacts but I plan on locating a used one and having it installed. The interior hasn't been touched, so it went bad on it's own.
Old Nov 8, 2010 | 05:02 PM
Blck350z's Avatar
Blck350z
u shouldve said something ^..... u can swap mine in and see if it works....
EDIT: I need it back though :/
Old Nov 8, 2010 | 05:50 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
AC amplifier. Try and find one from a part-out thread. Mine cost over $700 (parts+labor) from the dealer and it took them a week just to find the problem. If they would have just told me what it was I would have driven it around with no interior lights/speedo until I found one for cheap...oh well.
Old Nov 10, 2010 | 10:32 AM
BeamerGuy's Avatar
BeamerGuy
Originally Posted by jtgli
I checked all my fuses inside the cabin and under the hood and I can't seem to find out why my dash does not display the turn signals. To further explain, my turn signals do work but the dash does not display the turn signals that they’re working, same goes for hazard light button, lights are on and working but not showing up inside on the dash. Further my open door beep does not sound when the key is in the ignition, nor does the beep indicating that my headlights are still on. Lastly I am not getting a light on the dash when I put the high beams on. To be clear again hid bulbs everything works on the outside of the car, but no indicatiors or beeps are working on the inside. Anyone know what could be the cause?
There could be an internal short in the dash or maybe a power wire has come loose behind the dash.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
