thinkin about my keyZ
Old Nov 18, 2003 | 12:51 PM
ZZZealous007's Avatar
ZZZealous007
Default thinkin about my keyZ
Hi,
Im interested in buying a new key for my 350z. I was just wondering how the chip inside the original key works? Does it send out a radio frequency or does it send the signal thru the metal on the key? Does it require a battery to operate? And last but not least, how can I take out the chip?
If you have any pics, answers, or suggestions let me/us know.
...and yes I used the search button.
Old Nov 18, 2003 | 03:32 PM
alphared's Avatar
alphared
Default Re: thinkin about my keyZ
Originally posted by ZZZealous007
Hi,
It works on RF. no battery needed. think of it like those tag on clothing that sets of the alarm if you walk out the store without removing it. Why do you want to remove the chip?? I don't think you can really do it without damaging it. It's was probably put in while they were molding the key so that the plastic fills all the gaps.
Old Nov 19, 2003 | 05:32 AM
VandyZ's Avatar
VandyZ
there is a cap on the bottom of the key. If you look close you can see it. I dont know how easy it is to remove. I do know it does not seem to work by just putting that key near the ignition and using a non coded spare key. I am sure there is a trick to it.
Old Nov 19, 2003 | 09:50 AM
ZZZealous007
I was wondering if I could remove teh chip and have it on my key ring,since the aftermarket key does not have a place to insert a chip.
VandyZ
How do u know that the aftermarket key wont work if the chip is near it? Have you tried this before? i figured if the chip is truly RF then it should work in close proximity...such as on the same key ring or maybe if it was taped directly under the ignition.
Ive seen the little black rectangle on the bottom portion of the key before, but I didnt have any luck removing it. There has to be a correct way of removing it. Do we have any car security people here? The last thing i want to do is hack apart the key to get the chip.
Btw if ur wondering what key im currently looking to buy here it is:
http://store.freshalloy.com/nisblankeypo.html
im sure u guys have seen it before, i wonder if the key is the correct cut?
Old Nov 19, 2003 | 11:50 AM
350z-z33's Avatar
350z-z33
I'm interest in getting another key for my Z too but don't know how the chip will work (without bring it to the Nissan Dealer). Hopefully someone will post something helpful soon, thanks in advance.
Old Nov 21, 2003 | 06:51 AM
ZZZealous007
there has to be at least one person on this forum who has some experience with this topic....pleeeez help us! =T
Old Nov 21, 2003 | 11:30 AM
alphared's Avatar
alphared
I don't think anyone opened it. Have never seen any post on the subject. The key is pretty expensive and ripping it apart can make anyone nervous. You can be the first to try it and see if it works. I don't think that putting it on a ring would work since the range of the antenna is really short.
VandyZ the antenna is right above the solenoid, so I'm guessing about .5"-1" inch range to disarm it. So a unless the chip is on the key it probably will not work.
Old Nov 21, 2003 | 01:25 PM
ZZZealous007
thanks for the pic...that helps somewhat.
Can you/anyone get a schematic for the our keys? If i had this i may be willing to experiment with the Valet key. I need to know where to cut before I start.
Thanks for the help!
Old Nov 21, 2003 | 02:37 PM
alphared's Avatar
alphared
I was looking for a schematic for the key, but thats the only pic in the service manual that I can find on the topic. (well there is a crappy diagram on how the key connects to the antenna then to the bcm, but everyone knows that) theres really no pic that I can find since the service manual only offers repair topics. Guess nissan figures that its easier to replace the key than to fix it.
johnny2105
May 17, 2004 06:17 PM
TheBigShow
Nitrous Oxide
Feb 19, 2004 01:52 PM
TheBigShow
Jan 21, 2004 06:17 AM
Blue Batmobile
Nov 30, 2003 06:16 AM
Blue Batmobile
Nov 18, 2003 11:08 AM
