painted my headlight housings but... uh oh?
Old Dec 25, 2010 | 11:41 AM
dope619's Avatar
dope619
Default painted my headlight housings but... uh oh?
so i painted my headlight housings last night, and i'll get straight to the question. i only let the paint cure for about 2 1/2 hours, before i re assembled it. will the paint make haze on the inside of my plastic lenses? should i take them off as soon as possible? they have been assembled for about 18 hours or so.
where is the smack myself on the head smiley?
thanks.
Old Dec 25, 2010 | 01:10 PM
Vas_Z33's Avatar
Vas_Z33
what paint did u use? spray can? most of them are dry within 30 min.. at least mine did.. I didnt even wait for mine to dry to put em on .. ull be fine
Old Dec 25, 2010 | 01:12 PM
gvulakh's Avatar
gvulakh
You should be ok......as long as you didn't leave fingerprints on the painted parts from handling them so soon.
Old Dec 25, 2010 | 01:25 PM
4DGS's Avatar
4DGS
Depends, they probably have NOT degassed yet.
I always give them minimum 5-6 hours dry time, then I bake them before putting them back into the lens.
If they are done to quickley they can degas and permanently yellow the inside of the lens.
If you don't need the car, I suggest you pull them and leave the bulbs caps off for as long as you can.
Old Dec 25, 2010 | 01:55 PM
User 42426's Avatar
User 42426
hmmm, since its a pain to reopen and let them dry, just open up the bulb and let air get in there and leave it out for a while if your worried about it fogging up or turning yellow.
Old Dec 25, 2010 | 02:00 PM
POWUH's Avatar
POWUH
^^ how much do u charge for paiting and halo headlights?
Old Dec 25, 2010 | 02:36 PM
dope619's Avatar
dope619
thanks that makes me feel better. i used plastic rattle can spray. i used the clear silicone to seal it back up. but i think i wanna take it apart again and paint more of it.
heres my left and right lights, i know i need to refinish my lenses, but you can see what i didnt paint. its raining also.
and heres a shot of my side marker, i painted it, but left the spot where the light shows through.
can i black out everything, or has anyone blacked out everything except what i circled?
Old Dec 25, 2010 | 02:52 PM
dope619's Avatar
dope619
damn these are good ideas but i dont have access to a jack, wonder where my trunk jack is... any way to pull a bulb out without jacking up?
Old Dec 25, 2010 | 03:00 PM
Vas_Z33's Avatar
Vas_Z33
is that condensation? ... if so.. I hope you didnt assemble the unit
Old Dec 25, 2010 | 03:05 PM
dope619's Avatar
dope619
nope its raining, i drove through the rain today. wiped it to make sure, and it was dry inside.
Old Dec 25, 2010 | 03:08 PM
User 42426's Avatar
User 42426
hmmm, can you access the bulb from the hood at the top? I thought I saw a thread that showed how to access it from the top. Or, pull the bumper off and take of the headlight again, dont think you really need a jack to pull the bumper off, would help tho.
Old Dec 25, 2010 | 03:11 PM
User 42426's Avatar
User 42426
Btw, were you refering to me? Painting and doing the halo was a pain for me, but only because I took my precious time and wanted everything perfect. Drop me a pm if your interested, we can work something out...
Old Dec 25, 2010 | 03:43 PM
4DGS's Avatar
4DGS
You can't get in from the engine bay.
You need to turn the wheels and pull your fender liner to get in there, it's a *****.
Powuh; If you were referring to me and my sig, I only do it locally and don't do halos due to their failure rate.
Forgot to mention:
The stuff you circled can be painted but say good bye to your high beams, I've painted everything but the projector and it's really not that bad. Looks waaaaay better.
Old Dec 25, 2010 | 03:59 PM
dope619's Avatar
dope619
hey just to make things crystal clear, 4DGS, you painted all the chrome except
what i circled in this picture below, and that means you said bye bye to high beams, but your low beam output is fine.
i dont want to lose my high beams or low beams, but want to black out as much as possible, so should i paint everything except what i circle in this picture below?
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
Cashwin
Oct 1, 2015 06:36 AM
JGee450
Sep 30, 2015 04:32 AM
