Broken Headlight (HID), im lost!
Old Jan 27, 2011 | 10:30 AM
melikepaint's Avatar
melikepaint
Default Broken Headlight (HID), im lost!
Ok so i had a small fender bender in the front. I managed to hit the guy just right and smacked my drivers side headlight. I cracked the lens. At first it wasnt a big deal. And then as i drove, i guess whatever mechanism that aims the actual headlight broke loose. Now im stuck with it aimed all the way down and i cannot get it aimed back right.
My main thing is i guess i just need to replace the damn thing. So... Aftermarket headlights... All i can seem to find is the non-hid replacements.
Can i get the non-hid and still use my factory d2r hid bulb? The pictures of the 2 (hid and non-hid) look EXACTLY the same physically.
I have searched for this and cannot seem to find an exact answer. Please help.
Old Jan 27, 2011 | 11:24 AM
engiNERD350Z's Avatar
engiNERD350Z
No you will not be able to use non-HID in place of HID. The HID housing (the rear half that is black plastic) has a cutout for the ballast and other components to assemble to. On non-HID, this area is molded in. I suppose you could do some cutting of your own but I wouldn't try to. I think it's more than just cutting. It's been a while since I've seen them side by side but I've had both in my possession at the same time.
You may be able to mix and match parts with the non-HID to get all the working parts you need. However, I am not sure what the leveling component is attached to.
Old Jan 27, 2011 | 11:26 AM
marques1's Avatar
marques1
What year is your z?
Old Jan 27, 2011 | 12:31 PM
melikepaint
Sorry. Its an 03 touring.
Old Jan 27, 2011 | 12:43 PM
cubs4worldseris's Avatar
cubs4worldseris
Seems like a prime time to upgrade to 06+ headlights!
Old Jan 27, 2011 | 01:02 PM
zaperroni's Avatar
zaperroni
I have a brand new oem driver side headlight with factory HID for sale if you're interested.
let me know
Old Jan 27, 2011 | 01:31 PM
HID lights are powered by ballasts. Halogen is not. Swapping is not a simple plug-and-play
Old Jan 27, 2011 | 04:15 PM
melikepaint
I know this. Thats not my question. Im not doing a base to hid conversion (although that seems to be the only thing i find in my search). I just basically wanted to kno if the non hid and hid assemblies would accept the same bulb size (d2r). I wouldnt be worried about ballast placement too much either.
Im just honestly tryin to spend less as possible. And noone seems to make aftermarket hid type replacements.
Old Jan 28, 2011 | 07:41 AM
Sktz999's Avatar
Sktz999
The hid and non hid are 2 different bulb sizes, so in answer to your question is the d2r bulb will not fit in the halogen lights, I believe they are H7(someone chime in if that is wrong) and the wiring harness for hid is 8 wire while the halogen is 6 wire iirc.
I would say your best bet is take a look at just buying the driver side light from a member on here that is set up for HID. It also seems to be A LOT cheaper than going to 06 headlights.
just my $.02.
Old Jan 28, 2011 | 03:42 PM
melikepaint
just my $.02.
Aw yea no doubt, converting to 06 headlights is waaaaay outta my price range. And im thinkin the sizes you are saying are correct. Thats wat ive been seeing. And i fella on here has one for sale for a damn good price, im just a broke *** at the moment.
And the more and more i read into this, i think to myself, ive never seen a damn 350z without HIDs. So it just confuses me that all that i can find aftermarket to replace it are non-hid ones...
Guess im just gonna have to bite the bullet and get a oem part. Hopefully soon bc i cant see **** i night.
Old Jan 31, 2011 | 02:49 PM
melikepaint
Anyone else got any useful info?
Old Jan 31, 2011 | 03:29 PM
zaperroni's Avatar
zaperroni
let me know if you need a new oem part at a discount
Old Jan 31, 2011 | 03:58 PM
melikepaint
Will do man. Thank ya!
Old Feb 1, 2011 | 06:47 AM
350z_this's Avatar
350z_this
is the 06 hid just plug and play for an 04?
Old Feb 1, 2011 | 08:25 AM
melikepaint
I dont think so.
Old Feb 1, 2011 | 10:08 AM
ZKansasZ's Avatar
ZKansasZ
just my $.02.
Sorry to say this but you both are wrong.
I bought the black out Ebay headlight, which has H7 bulbs, and I transferred the entire set of HID kit from my OEM HID touring light over.
Of course there are cutting the plastic cover at the bottom. But the ballast bases fit perfectly in.
And it will take you about a half day to migrate all the harnesses and modify the little bulb holder a bit to fit.
But I guarantee it will fit!
just take your time and do it if you want to.
Old Feb 1, 2011 | 10:14 AM
ZKansasZ's Avatar
ZKansasZ
Oh and you might have to cut out the turn signal and the parking light wire because those bases will not fit the after market housing.
Just spice them into the after market housing turn signal and parking light bases.
Dont be scared! :-)
Old Feb 1, 2011 | 01:51 PM
bbs350z's Avatar
bbs350z
yes. if its hid its plug and play
op, spend $100 and get a used light.
Old Feb 3, 2011 | 06:59 PM
melikepaint
Find me one good sir. Haha. I cant find one with that low of a price.
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
Dymsi
Sep 29, 2015 11:32 AM
