Door wont close all the way
Old Jan 28, 2011 | 04:25 AM
chodalak's Avatar
chodalak
Default Door wont close all the way
hey, i notice my driver side door wont close all the way,
im just wondering if there are any adjustment points or anything to get it to be flush with the rest of the car.
Old Jan 28, 2011 | 05:51 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Is your window frozen in the up position?
Old Feb 1, 2011 | 07:47 AM
chodalak's Avatar
chodalak
noo, it does its think every time i open and close, like its only siticking out like 3 mm +/-...,
i tried playing with that hook that attaches to the B pillar..were the seatbelts go, but looks like it cant adjust.
like i can push it in if i lean on it, but when i stop it comes out the few milimeters
EDIT: btw thanks for posting your thoughts, any interests and ideas will help!
Old Feb 2, 2011 | 06:11 AM
BoomerZ33's Avatar
BoomerZ33
is the weatherstripping rubbing at all? the actual door hinge might need to be checked as well.
Old Feb 2, 2011 | 08:49 PM
chodalak's Avatar
chodalak
yea maby the weather striping moved and is pushing door out, and ill get the all that checked out (this happend B4 i crashed my car) so i know its not related...i guess ill spend a few hours on it and see if i figure it out..i usualy do. thanks for the help guys
Old Feb 3, 2011 | 08:27 AM
Done Deal DR's Avatar
Done Deal DR
The only true adjustments to the door are found underneath the fender. If you remove the fender you will find the mounting locations.
It's possible the door could be sagging, but usually that would only occur if the door had been removed or the car had been in an accident.
I created a thread on installing the GT Spec fender braces that will show you how to get to these bolts. You will almost certainly need a friend to help you if you're going to tackle this, as you need to hold the door and also loosen/tighten these bolts. It's possible you could use a jack but an extra set of hands is recommended.
https://my350z.com/forum/brakes-and-...s-install.html
Old Feb 4, 2011 | 07:43 AM
chodalak's Avatar
chodalak
thanks a lot! i think this is the answer i have been waiting for.
Old Feb 4, 2011 | 08:07 AM
Done Deal DR
No problem, let us know how it works out.
Old Feb 4, 2011 | 08:14 AM
BoomerZ33's Avatar
BoomerZ33
hmmm good advice Done Deal. that's probably OP's case since he said he did crash the car
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
bcoffee20
Nov 19, 2015 06:39 PM
roadmax
Sep 12, 2015 05:55 PM
AP350z223
Sep 8, 2015 04:38 PM
