TSB for steering column wiring/VDC issue?
Old Feb 14, 2011 | 10:50 AM
bmccann101's Avatar
bmccann101
Default TSB for steering column wiring/VDC issue?
Pretty much just that.. i searched "TSB" and "TSB steering" for a thread or a sticky, didnt find anything...
every once and a while at low speed ( on ramps etc) while turning ....my power cuts out momentarily and i get a slip light.. i hear this is a known issue and has to do w grounding issues in the column.... and is very expensive to fix at the dealership.
I know how to wire 12 volt well, and would like to tackle it myself.
Anyone have a thread to reference for this or the TSB # so i can get started?
thanks.
Old Feb 15, 2011 | 09:03 AM
bmccann101's Avatar
bmccann101
hmm, been having a hard time getting answers on here lately on anything aside from the flashy trendy stuff. Seems like the " What offset should I run" repeat posts get more attention....
Anyone want to help me out? I know youre out there..
Old Feb 15, 2011 | 09:09 AM
DavesZ#3's Avatar
DavesZ#3
I've never heard of a TSB that sounds like what you describe.
The problem you describe sounds like the classic "wrong tire size". What size front and rear tires do you have?
Old Feb 15, 2011 | 09:12 AM
bmccann101's Avatar
bmccann101
thanks Dave.. i appreciate the response.. I gota go back into one more hour of training, but Ill reply w the tire sizes asap. It only happens when im at a increased steering angle, and i do have a rub noise in my column lately.
I believe the tires are 255 35 20 and 275 30 20
Old Feb 15, 2011 | 09:17 AM
terrasmak's Avatar
Thats what i was going to say.
Well from my experiance, if there actually is a slip issue being caused but the colum its because the steering angle senser is out of adjustment (screwed mine up while doing headers) either it needs to be reset at the dealer (consult) or the part needs to be replaced $130 and 1 hour of work, very simple. Then the reset at the dealer.
Hope this helps.
Old Feb 15, 2011 | 10:30 AM
bmccann101's Avatar
bmccann101
yea im not pulling any codes tho.. its WEIRD.
I googled it and found this thread :
http://www.350zmotoring.com/forums/3...ip-lights.html but IM not a member of that forum and rarely visit it. I posted this just to give youall an idea of what my issue is..
possibly related, my ABS pulses on its own right as i coast to a stop at a light, when most of the braking force is already done, jsut on my final braking before full stop.
Maybe this smacks of a known issue, maybe not.. its a lame gremlin for sure. And also makes driving it a pain instead of a pleasure as intended.
Old Feb 15, 2011 | 10:59 AM
bmccann101's Avatar
bmccann101
How'd my tire sizes check out?
Old Feb 15, 2011 | 11:49 AM
terrasmak's Avatar
Front tire is taller than your rear, that will cause a VDC/TCS/ABS issues. Throw a 255/30-20 up front.
Old Feb 15, 2011 | 12:02 PM
bmccann101's Avatar
bmccann101
i figured they were close enuff to be good to go.. i actually have diff rear tires going on as soon as my wheels get in... 305 25 20..
i know actual rolling diameteres differ, but the math i used was 255/25.4= 10.03 in wide tire. 10.03 x.35=3.51.
3.51 x2 +20=27.02 rolling for front..
275/25.4=10.82.
10.82x.3= 3.25
3.25x2+20=26.49 rolling for rear.
Will a half inch really cause this VDC issue?
new rears would be 12 in wide and after the math, im realizing are now even shorter.. 26 inches.
damnit. I will need new front tires. Too bad, these ones are sick, nice big fat tire up front. Brand new too.
Old Feb 15, 2011 | 12:10 PM
terrasmak's Avatar
275/25.4=10.82.
10.82x.3= 3.25
Actually its a full inch difference. If you remember your front tires are 3/4 of an inch shorter that the rears from the factory. All in all, rear tires need to be taller than the fronts or you will have problems.
Old Feb 15, 2011 | 12:36 PM
DavesZ#3's Avatar
DavesZ#3
It's not so much the magnitude of the difference, it's that the front is taller than the rears. The whole braking computer is designed off the assumption that the fronts are shorter than the rears. That allows the computer to observe wheel rotation rates and make assumptions about what is going on. If the fronts are taller, then they rotate slower than the rears. That makes the computer think the rears are slipping. When you turn the car, that exaggerates the rotation mis-match. Having TCS/VDC trigger on an on/off ramp is one of the most commonly reported symptoms of this - wrong tire size - problem.
Old Feb 15, 2011 | 01:10 PM
bmccann101's Avatar
bmccann101
yikes.. sorry for wasting everyones time w replies.. i actually have 255 30 20 up front, 275 30 20 out back, so the rear is indeed taller.. hmm.
Back to steering angle sensor maybe?
Regardless, i do appreciate the replies thus far. It still helps my process of elimination.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
