Bolts stuck in hatchback
Old Mar 21, 2011 | 08:01 PM
KevinDuzit's Avatar
KevinDuzit
Default Bolts stuck in hatchback
Recently i decided to put on an oem spoiler on my z and somehow the bolt was off by literally 1mm, so now its touching the steel around it and their is no way i can get the bold on correctly, so i took it to the body shop and asked them to install 2 bolts for my and they lost the bolts inside my hatch and now there is a rattling sound every time i drive. I was wondering if you guys could help me find a way to get them out? Maybe a super magnet? lol Thanks guys.
The place where im supposed to put the bolt:
<a href="http://photobucket.com" target="_blank"><img src="http://i248.photobucket.com/albums/gg195/thizz1127/03dc4f79.jpg" border="0" alt="Photobucket"></a>
Where the bolts are:
<a href="http://photobucket.com" target="_blank"><img src="http://i248.photobucket.com/albums/gg195/thizz1127/00faf19d.jpg" border="0" alt="Photobucket"></a>
Old Mar 21, 2011 | 08:17 PM
kraZybones88's Avatar
kraZybones88
Good luck buddy!! I have the same problem I was installing my nismo v2 spoiler and I dropped a 10mm socket in there as well. Ive tried everything to get it out and nothing!! Taking sharp turns to make it roll to one side and maybe get it out with a magnet. I drilled wholes about an inch in diameter right by where the hinges are, to see if I clould get lucky and get it through there and nothing! so I gave up! Its been in there for about a year now. And yes it is annoying!! when that ishh rolls in there!! Lol.
Old Mar 21, 2011 | 08:22 PM
KevinDuzit's Avatar
KevinDuzit
i know is there anyway to remove the hatch somehow? yes its that annoying lol
Old Mar 21, 2011 | 08:35 PM
terrasmak's Avatar
I just left the panels off and drove around. It took about 3 days before it fell out. You can try a magnet on a flexible shaft, you may be able to get it.
Old Mar 21, 2011 | 09:08 PM
kraZybones88
Im sure you can remove the hatch otherwise other members on here would be able to install cf hatch. Although I dont think that would be much help.
I have left my panels off "hoping" it will come out but no luck either.
Old Mar 21, 2011 | 09:26 PM
JasonZ-YA's Avatar
JasonZ-YA
drill holes, spray expanding foam, encapsulate and leave it in there stuck and it wont roll around to make noise...
-J
Old Mar 22, 2011 | 09:54 AM
endless_summers's Avatar
endless_summers
-J
Oh man I can't wait to see pics!
Old Mar 22, 2011 | 10:42 AM
andrew's 350Z's Avatar
andrew's 350Z
If u want to take the hatch off- you have to take the 2 shocks off then pull a little of your headliner off then where the hatch connects to the car there are 2 bolts on each side that come off with a 10mm socket. ( located under the headliner near the top of the trunk)
Old Mar 22, 2011 | 06:45 PM
terrasmak's Avatar
-J
Not a good idea, it can and will seperate the skin from the structure if you do this. There are many pics around of attemps on hoods, it destroys them.
Old Mar 23, 2011 | 07:12 PM
JasonZ-YA's Avatar
JasonZ-YA
^ what product was used? if using the right product it should work no?
-J
AbrasiveRaysive
Sep 20, 2021 02:29 PM
wanderingstuden
Jan 28, 2016 07:03 PM
