Plasti-Dip Questions & Projects Thread
Old Mar 22, 2014 | 06:25 AM
  #521
frjr3's Avatar
frjr3
[QUOTE]
Originally Posted by SQuaLZ
Yea because it takes some attention away from the fugly taillights.
Well then my goal was accomplished then
What's wrong with your lugs? Lock nuts and don't have the key?[/QUOTE
Bought the car, lug nuts never came to mind. First time wanting to take wheels off which was to plasti dip them, I realized NO key...-facepalm- and a good lesson learned
Old Mar 22, 2014 | 06:55 AM
  #522
mr. sparco's Avatar
mr. sparco
Lugs look to be ordinary 19 or 21mm 6 point socket. Are you trying to remove the wheels with the stock hardware?
Old Mar 22, 2014 | 07:08 AM
  #523
frjr3's Avatar
frjr3
well I plan to measure and use a socket that barley fits it, and hammer it in good, then use a 1/2 breaker bar and hope for the best.
As far as the stock hardware ill only use the jack. I hope to order lug nuts today so I can attempt it next week...hopefully I do not get a flat till then.
I could get new locks only but I don't like the chrome lug nuts.
Old Mar 22, 2014 | 11:13 AM
  #524
SQuaLZ's Avatar
SQuaLZ
As sparco said, it looks like normal 6 point lugs.
But yes if they are indeed locks use the plan you said. Make sure it's not a good socket though, since it will be destroyed by the time your done.
Look into Gorilla. I love my Gorilla lugs, IMO better than OEM quality.
Old Mar 22, 2014 | 12:19 PM
  #525
frjr3's Avatar
frjr3
They are, Yeah ima have to sacrifice the socket(s) lol. I looked them up, I actually like them, Indecisive whether to go for blue or black ? There the small acorn style.
Old Mar 22, 2014 | 02:10 PM
  #526
SQuaLZ's Avatar
SQuaLZ
I have both. I originally bought the blue but they are too much for my car so I bought the black. Still use the blue on my winter wheels that are white stockies. I prefer the black though anyday.
Old Mar 22, 2014 | 03:46 PM
  #527
frjr3's Avatar
frjr3
Well I put my order in for the blue ones now to await and brake the lug nuts then redip. If anything I can plasti dip the lug nuts black if i dont like them ahaha...jk but thx for the suggestion I hadn't heard of gorillla.
Old Mar 27, 2014 | 08:58 AM
  #528
djraid619's Avatar
djraid619
Would anyone recommend using plasti-dip to "paint" a fiberglass lip?
Old Mar 27, 2014 | 09:40 AM
  #529
Arsenal350's Avatar
Arsenal350
It would probably hold up to rock chips a littler better than standard spray paint thats for sure. Im thinking about spraying my entire car because my clearcoast is turning into dust. Thats until I can afford a legit paint job.
Old Mar 27, 2014 | 09:48 AM
  #530
CJM's Avatar
CJM
It would add another layer of protection to your lip and shield it from mild scratches and rock chips. I would recommend it.
Old Mar 27, 2014 | 02:22 PM
  #531
djraid619's Avatar
djraid619
So what do you think? Prep the lip, paint it and then plastidip it or should I skip the painting and just plastidip after it's prepped?
Old Mar 27, 2014 | 02:41 PM
  #532
CJM's Avatar
CJM
I would not paint it personally if you are going to cover it in PD in the end. Also, Plasti Dipping over fresh paint is not advised as some have experienced a staining of the clear coat (usually fixable with time and sun). It is advised to wait at least 6 months after paint before applying PD. So yes, I would just have it prepped and then dip it.
Old Mar 28, 2014 | 10:06 AM
  #533
djraid619's Avatar
djraid619
Awesome! Thanks for the advice.
Old Mar 29, 2014 | 09:35 AM
  #534
paintballer95's Avatar
paintballer95
Default My 350z Inside and Out. PLASTIDIP!
Rims and Handles
Engine!
Inside Rear Support!
Door inserts!
Door Switches!
Passenger Door Switches and Handlebar!
Center Console!
And new Shift ****!
Plastidip, i used regular black, and then coated over it with copper metalizer! i love the look!
Old Mar 29, 2014 | 10:19 AM
  #535
Rocknthehawk's Avatar
Rocknthehawk
Old Mar 29, 2014 | 10:49 AM
  #536
KornerCarver's Avatar
KornerCarver
It appears you did a fairly good job with the Plastidip. However, I would peel that crap off my car before the sun sets tonight. That is ok for a Honda, but a Z deserves better,
Old Mar 29, 2014 | 10:54 AM
  #537
JCITY's Avatar
JCITY
To each his own...
Not a fan.
Old Mar 29, 2014 | 11:29 AM
  #538
Bmurray350z's Avatar
Bmurray350z
Little overboard....
Old Mar 29, 2014 | 03:14 PM
  #539
BY350z's Avatar
BY350z
Out of all the ricy-dipped colors you went with the doo doo brown
Old Mar 29, 2014 | 07:11 PM
  #540
HR.R-CING's Avatar
HR.R-CING
