Seibon OEM CF Hood
Old Mar 30, 2011 | 11:43 AM
SharX59's Avatar
SharX59
Default Seibon OEM CF Hood
I just picked this up and had a body shop (which has no experience installing aftermarket anything on a car) install it on my car. Well I get what I deserve...the fitment is off completely. I just want to make sure that its there fault and not the hoods "flawed design". I was told that the OEM styled hood for the 07-08 z is supposed to be a near perfect replacement (doubt that). Has anyone had problems with fitment? Should i just go to another shop to re-fit the hood?
PIX to come
Old Mar 30, 2011 | 11:46 AM
r_seng's Avatar
r_seng
Any aftermarket body piece is not going to fit like OEM. It will require work, how much work is determined by how sh*tty the piece it.
Old Mar 31, 2011 | 12:14 PM
melikepaint's Avatar
melikepaint
I got a Seibon top secret style hood for my 03, it fits like butt too. But its close enough for me.
Old Mar 31, 2011 | 07:45 PM
SharX59's Avatar
SharX59
Given I knew aftermarket wouldn't be perfect, however I didn't expect it to be this bad. In any case, I'll be making my way to DTM to see if they can refit it. I'll take pix and post them tomorrow.
Old Apr 1, 2011 | 12:12 PM
ZS14RR's Avatar
ZS14RR
Sucks man..pics and better description on where its off?
Old Apr 1, 2011 | 12:53 PM
SharX59's Avatar
SharX59
ill have the pix up around 6 ish....and its off on the left and right fenders (one side is closer to the fender than the other) and its off at the top of the headlights (gap).
Old Apr 1, 2011 | 08:46 PM
SharX59's Avatar
SharX59
<a href="http://s117.photobucket.com/albums/o50/sharx59/?action=view&amp;current=0401011821b.jpg" target="_blank"><img src="http://i117.photobucket.com/albums/o50/sharx59/0401011821b.jpg" border="0" alt="Photobucket"></a>
<a href="http://s117.photobucket.com/albums/o50/sharx59/?action=view&amp;current=0401011821a.jpg" target="_blank"><img src="http://i117.photobucket.com/albums/o50/sharx59/0401011821a.jpg" border="0" alt="Photobucket"></a>
<a href="http://s117.photobucket.com/albums/o50/sharx59/?action=view&amp;current=0401011821.jpg" target="_blank"><img src="http://i117.photobucket.com/albums/o50/sharx59/0401011821.jpg" border="0" alt="Photobucket"></a>
More gap between the hood and the fender.
<a href="http://s117.photobucket.com/albums/o50/sharx59/?action=view&amp;current=0401011820.jpg" target="_blank"><img src="http://i117.photobucket.com/albums/o50/sharx59/0401011820.jpg" border="0" alt="Photobucket"></a>
Less gap
Old Apr 1, 2011 | 10:27 PM
cambochino's Avatar
cambochino
the fitment is so perfect. i have Seibon TS n it fits perfect to my car
Old Apr 2, 2011 | 12:20 AM
SharX59's Avatar
SharX59
well, I'm happy your happy...but your happiness doesn't help me :/ lol
Old Apr 2, 2011 | 06:32 AM
gixxert's Avatar
gixxert
it looks like they just needed to move the front of the hood over to the passenger side a bit since that side is bigger then the driver side. get two friend loosen the rear bolt on the driver side and the front bolt on the passenger side that hold the bracket to the hood and try sliding it over a bit
Old Apr 2, 2011 | 07:01 AM
SpoilsofWar's Avatar
SpoilsofWar
That fit is probably better then you should even be expecting with an aftermarket carbon piece.
Old Apr 2, 2011 | 07:23 AM
e46330i's Avatar
e46330i
Looks pretty good to me :/
Old Apr 2, 2011 | 12:01 PM
SharX59's Avatar
SharX59
Well I'm very **** about my car. It wasn't my intention to buy a cf hood but it saved me money. If i cant get it to be even, then I will sell it and get OEM.
Old Apr 2, 2011 | 12:06 PM
SpoilsofWar
There is some adjustment in the hood hinges where they bolt to the hood because the bolt holes are ovals, not round. So, you could maybe slide the hood forward a little to fix some of that over-headlight gap.
Really though, for a carbon part from Seibon, VIS, etc, you should be happy with that fit. If it bothers you, then yeah, you need to buy an OEM hood.
Old Apr 2, 2011 | 12:11 PM
SharX59's Avatar
SharX59
I think I'll get together with some friends and try sliding it over a bit. if it sits evenly then I'll be happy. I knew the cf wouldn't sit perfect but I didn't expect it to be like this. Lets see what happens.
Old Apr 2, 2011 | 02:22 PM
BoomerZ33's Avatar
BoomerZ33
i've seen worse OP. i had great fitment with my seibon hood
Old Apr 2, 2011 | 04:15 PM
oddjobbb's Avatar
oddjobbb
my Seibon fit is very good but my body guy
had to enlarge the hinge holes to give him more wiggle room. next time take it to someone who is familiar with aftermarket parts and how to make them fit better.
Old Apr 12, 2011 | 08:15 AM
SV1098's Avatar
SV1098
The fitment on mine is pretty dead on.. You really have to adjust it a few times to get it perfect.
IMO--If you wanted to paint the CF hood from the start, I would have stayed with the stock hood as its a little lighter and is OEM.
Justin100
Nov 25, 2021 06:26 AM
350z82
Oct 1, 2015 06:25 PM
