New headlights for 04 base
Old Apr 15, 2011 | 03:25 PM
AJCaron12's Avatar
AJCaron12
Originally Posted by SemperFly
Ur a goon. Sometimes things can be improved for wutever reason. The guy before op just did a **** poor job.
I'm a goon cause I don't do stupid shyte that will cause me problems down the road, or half azz for that matter too
Old Apr 15, 2011 | 04:05 PM
gregom's Avatar
gregom
Ok ok... i'll go $175.
I should work at a dealership with those low-balling skills don't you think?
Old Apr 15, 2011 | 07:23 PM
Phantom10's Avatar
Phantom10
ok I'm gonna get some 6k HID bulbs from ebay (I want that blue-white look), and wetsand them first to see if this will solve my problems.
Thanks for all of the help guys.
I will let you all know if I decide to sell them or whatnot.
Old Apr 15, 2011 | 07:59 PM
gregom's Avatar
gregom
It's just the outer lens that is all trashed... it looks easily fixable honestly. I'm betting the projectors weren't touched and once you get the outer lens cleaned up and some closer to stock color temp HID's in they will work great.
Make sure things are sealed well so water can't get inside. Get some clear silicone weather sealant and cover up holes and such that need it. The silicone isn't super adhesive so if you have to remove it later on you can without much difficulty.
Old Apr 15, 2011 | 08:01 PM
surfcity40's Avatar
surfcity40
Originally Posted by acke15
headlights shipped to 46038 please
this made me laugh
Old Apr 26, 2011 | 06:59 AM
Phantom10's Avatar
Phantom10
The body shop said that the headlights are ruined, along with the wiring.
The shop says they can order a brand new pair for $400 which seems like a high price to me. Where can I find good headlights for cheaper?
Sounds like I could get a custom pair from www.cincitydesigns.com for around that much.. What do you guys think
Old Apr 26, 2011 | 12:40 PM
acke15's Avatar
acke15
what did u do with the "ruined" headlights?
bump!!!
Old Apr 26, 2011 | 03:03 PM
bagged00's Avatar
bagged00
a few things that i question about the set up. you have an 04 and those are 06 headlights. 06 headlights not only use a whole different wiring harness but also the pigtails for the other bulbs like turns signal and running lamps are different. the clocking isnt right on them. so how were those bulbs installed and locked into place.? also, does a 04 hid fit into an 06 hid? i know when i put my 06 headlights back in my 06(had 03s in it when i got it) i didnt check but it didnt seem that the aftermarket hid would fit into an 06 hid bulb location. so makes me wonder how the bulb is held in there? also theres 2 big holes in the headlight. one is covered by a cap the other by the hid ballast, id be willing to bet one of those arent covered letting your moisture in. if i was you i take them out see what was going on. stick them in the oven if needed, open up clean them out then reseal properly. not hard at all. i just open up my 03 headlights i had laying around.
btw the previous owner of my car gave me the facotry 06 headlights that were in my car originally for free i was pretty excited.
Old Apr 26, 2011 | 07:33 PM
xX Lil Oly Xx's Avatar
xX Lil Oly Xx
I bet you when he put in the oven he left the wire on the light
I customize my headlight!
Old May 16, 2011 | 10:04 AM
Phantom10's Avatar
Phantom10
These headlights are now for sale. I went ahead and got new oem headlights for my z, so I no longer have any use for them.
A post will be made soon in the marketplace forum regarding them. Pm me if you are interested
Thanks
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
