Paint is chipping on rear bumper.. suggestions?
Old Apr 17, 2011 | 04:25 PM
cityslick43's Avatar
cityslick43
Default Paint is chipping on rear bumper.. suggestions?
Hey evreyone, I drove my Z in the snow and the rear bumper paint is chipping off I dont have a pic at the moment but there are 3 major areas about 5 inches by 5 inches of black paint that has come off.. any suggestions to what I could do to touch up.. repainting will cost $400 not looking to spend that much, can I sand the bumper spray paint and clear coat?
Old Apr 17, 2011 | 06:05 PM
Kulwiec's Avatar
Kulwiec
please dont =[
Best way to get it done the RIGHT way is to take it to a shop.
The cheap way is hardly ever the right way.
Old Apr 17, 2011 | 06:07 PM
cityslick43
Very true but I dont think I will ever have $400 to spare in the near future do you know of anything else I can do?
Old Apr 17, 2011 | 06:11 PM
bagged00's Avatar
bagged00
only to options is touch up or repaint. something like, spots need to be sanded and feather with 180 and primed in. sand whole bumper, put color on the primer spots and clear whole bumper.
Old Apr 17, 2011 | 06:16 PM
cityslick43
as in 180 grit sand paper? I plan on doing this tomorrow.. Can you tell me how to do it.. Take bumper off, clean it, sand it, spray it, clear coat? what kind of paint?
Old Apr 17, 2011 | 06:22 PM
bagged00's Avatar
bagged00
for a body shop its gonna take no time. for an ameteur(sp?) it may be a little harder. all of this needs to be done with an automotive paint out of an automotive paint gun, not rattle can clear. theres is a technique to useing automotive paint gun. its not as easy as pulling the trigger and going.
take bumper off
feather out the hard paint edges wit 180.
sand over the 180 scratches and a little further out with 400
prime to the 400 scratches making sure all 180 scratches are primed over. base coat can fill 400 scratches, not 180
let primer dry about 3 or 4 hrs depending on weather
sand primer with 600
sand reast of bumper with 800
wipe down with wax and grease remover
dust in the primer with color and blend out a little bit
tack off with a tack rag
put 2 coats a clear allowing proper flash time in between coats
this is a rough how to with out going to indepth
Old Apr 17, 2011 | 06:37 PM
cityslick43
Thanks a lot but I do not have a paint gun, its not the whole bumper just touch up do you think I can do all that but use a spray can?
Old Apr 17, 2011 | 07:18 PM
User 42426's Avatar
User 42426
just leave it and save up for a paint job
Old Apr 17, 2011 | 07:58 PM
bagged00's Avatar
bagged00
^wird. No sir just save up and get the bumper painted. It will look like **** with rattle can
Old Apr 18, 2011 | 01:33 PM
bmccann101's Avatar
bmccann101
everyone you ahv asked has said there is no QUICK way to do this. Take the advice of the masses.
While i work hard for my money and am not wealthy by any means, 400 dollars for the 350z is not alot to spend, especially on something that heavily affects the resale or residual of your car.
as they say " good //cheap //easy..... pick two". end of story.
Old Apr 18, 2011 | 01:42 PM
verdict.'s Avatar
verdict.
Honestly, I would either save up and do it the right way or not touch it at all. Stay away from using a rattle can.
Rev_Night
Nov 7, 2020 06:00 PM
