headlight help please dont bash me lol
Old May 14, 2011 | 03:13 AM
epidemic007's Avatar
epidemic007
Default headlight help please dont bash me lol
ahhhhhhhhhhh i need new wire harnesses and headlights for my 06. i would love to get a set of 06 headlights but truthfully i cant spend that kind of money, if i were to purchase 04 headlights would i need the 04 harness? dont really wanna get into reasons on why i im in this pickle all i wanna say is a bodyshop that i did trust effed me and closed down while car was being worked on, took my money and i was forced to order a set of ebay headlights....fail all across the board. i keep buying hid kits and they keep goin out on me so now i wanna go back to oem spec. please no bashing, im already stressed enough because of stupid headlights....i need good advice and possible solutions........
Old May 14, 2011 | 01:31 PM
nismo1234's Avatar
nismo1234
if you get the cheap basic 200$ heasdlights off ebay they wont work the plug is different from the base models to the ones with factory hid
the upper models have a wider plug so if you do get something off ebay make sure it has factory hid and it should be a plug and play. good luck with everything tho.
Old May 14, 2011 | 03:03 PM
epidemic007
yea i learned that the hard way.....im lookin to buy oem now and fix this problem the correct way now that finnances are back in order, if i can find the 06 and up bi-xenons for 800 a pair as oppse to 800 each im willing to do that
Old May 15, 2011 | 09:13 AM
Al Kapwned's Avatar
Al Kapwned
lol at this fail
Old May 15, 2011 | 10:39 AM
We have members who are electrical geniuses. HID to halogen. Halogen to HID. Mix lights and harnesses. Snip - snap there you go.
Unfortunately I am not one of these special people and neither are you: If you drive a 2006 get 2006 headlight and 2006 harness. Done.
Good luck.
Old May 15, 2011 | 08:09 PM
gregom's Avatar
gregom
Do you still have stock HID ballasts? You can get 06+ headlamps for $800 without the ballasts and bulbs.
Old May 15, 2011 | 08:19 PM
gregom's Avatar
gregom
This is where I bought mine... http://cgi.ebay.com/ebaymotors/NISSA...Q5fAccessories
Doesn't have ballasts, bulbs, or the plastic cover on the back. Other than that they are brand new and work wonderfully.
Old May 15, 2011 | 10:14 PM
raycs7's Avatar
raycs7
The base model has halogen.
Those ebay lights without the ballast cutouts and 6 pin connectors will pnp.
04s with Xenon has 8 pins on the headlight connectors.
Is your car base model?
Old May 16, 2011 | 03:06 AM
epidemic007
Yea its a base model, yea im gonna go for 06 headlights....disregard the using of 04
Old May 16, 2011 | 03:08 AM
epidemic007
i dont have the old ballast....bodyshop that had car closed down on me, i felt i was lucky to even get my car back....major fail
Old May 16, 2011 | 04:58 AM
raycs7's Avatar
raycs7
I think the IDPM for the base may be different also.
I have a 2003 base with the complete front stripped.
I bought a replacement harness from a vendor here thinking it was xenon but was not.
I discovered the mistake too late and gotno reply to my emails.
The pins may be the same though.
I have been away from home for 6 months and cannot check until next month.
Old May 16, 2011 | 05:42 AM
gregom's Avatar
gregom
If you have an 06 like you said, it had OEM HID from the beginning, even if it was base model. 06 is when they ALL got HID. 03-05 base had halogens, all other trims had HID.
You can buy the ballasts at a lot of places, they are Matsushita brand. Try ebay... Used is fine frankly, these are excellent, reliable ballasts and I wouldn't be afraid to buy used. Also get some decent name brand HID bulbs, 4100K or 4300K color temp is stock. Get new on those... You should be able to do all this for under $1,000 or at least really close to it.
Oh and regarding this shop... depending on how much stuff of yours they kept you might consider filing a claim against them in small claims court. That is BS they still have stuff from your car. Your not 'lucky' for getting your car back, you own it and it is rightfully yours. If you don't get a fair deal, take them to court. Don't let them jerk you around and get their way. Hire an attorney if needed. But if it is less than a $1000 of parts it may not be worth the effort, depending on who you are.
Old May 17, 2011 | 03:05 AM
epidemic007
correct the original headlights were those sexy *** bi-xenons which i regret i dont have anymore. base model came stock with them, its amazing the problems i have with car sometimes but little by little everything is getting corrected....love her too much to get rid of her.
Old May 17, 2011 | 05:01 AM
BoomerZ33's Avatar
BoomerZ33
as stated above, search for the 06 bixenon setup. don't settle for the 03-05. and feel free to share your story in the northeast section if you wish so that others may be able to avoid this shop that scammed you in the future in case they ever reopen business again. good luck
Old May 18, 2011 | 03:07 AM
epidemic007
YEA ur def right man, im waiting on a call back from from one of the old mechanics at my dads dealership, hes now a service advisor at nissan. lets see how this plays out.
Old May 18, 2011 | 09:21 PM
aduhm619's Avatar
aduhm619
I was looking into moving up to the 06+ headlights, but I can't justify spending that much money.
"...a set of ebay headlights....fail all across the board." Yup
Plus hid kits usually have tons of issues. They'll go out or start to flicker with a little bit of time.
Stick with OEM. Good luck with the car.
Old May 18, 2011 | 09:39 PM
gregom's Avatar
gregom
Generally I agree but there are a few quality aftermarket brands out there. Reliability depends on the quality of the parts and the quality of the install. If you do a crappy job installing it, even excellent quality parts can break. I've ran on a set of aftermarket HID ballasts and bulbs for over 5 years in a previous car.
I must say though our OEM "Matsushita" brand ballasts are awesome! I've had water in them before and after shaking it out (literally) and letting it dry a few hours it still works. Now that is impressive.
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
