My headlights are foggy..
Old Jul 12, 2011 | 10:37 PM
BlkdOutZ's Avatar
BlkdOutZ
Default My headlights are foggy..
The lenses need to be replaced and I was wondering if anyone knew if anybody sells just the lenses, I really dont want to have to buy whole new headlight assembly..
Any help would be greatly appreciated!
Old Jul 12, 2011 | 10:42 PM
Stock2Autocrozz's Avatar
Stock2Autocrozz
2sand.com adapter, 1k &2k grit...sand w drill, buff smile @ new tools and saving hundreds
Old Jul 12, 2011 | 10:47 PM
marques1's Avatar
marques1
Get a pair of ebay headlights and take the lenses off of them. Then put them onto you're oem set, this will set you back about $140 dollars but you will have brand new lenses. They fit perfectly by the way. Just make sure that when you put the lenses on to your oem set to silicone really well, so that water does not get into the housing and short your ballast out.
Old Jul 12, 2011 | 11:01 PM
BlkdOutZ's Avatar
BlkdOutZ
I have heard of both of these options but i was hoping someone out there might have just the lenses..
and I couldnt find that adapter for a drill on that website, could you send me a link?
Old Jul 12, 2011 | 11:59 PM
ASpecTL's Avatar
ASpecTL
Probably better off using a headlight restoring kit you can find in automotive stores or walmart. Speaking of which, I need to get one
Old Jul 13, 2011 | 02:32 AM
ASTIG_Z's Avatar
ASTIG_Z
I sanded my lenses and they are very very clear now. I did the whole 3M process as described and came out with great results. sorry i dont have pictures to for example, but with a little effort, you can get away with restoring your lenses to almost new in a little over an hour.
http://www.amazon.com/3M-Headlight-L.../dp/B001AIZ5HY
http://solutions.3m.com/wps/portal/3...g_a_Headlight/
Old Jul 13, 2011 | 08:01 AM
bmccann101's Avatar
bmccann101
24 dollars for everything at a CSK checkers Schucks Kragen Autozone etc.
meguiars.
Old Jul 13, 2011 | 08:06 AM
ZS14RR's Avatar
ZS14RR
wet sand and buff.
Old Jul 13, 2011 | 08:58 AM
Stock2Autocrozz
Headlight restoring kits are barely a final step...on 2sand.com, part of their dustless sanding discs has a suggested adapter.
Buffing should and will be the final step, at that point grab any buffer, I use my rotary on that part and use PlastX...thats all the meguires kit is basiccally is a buffing adapter, towel and Plastx
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
