Urgent ! Locked out
Aug 13, 2011 | 11:28 PM
Urgent ! Locked out
my battery is disconnected and all the doors are locked , and the hatch as well, i can not access the car , is there any ways to open the hood from the outside ?? like an emergency latch.. ???!?
i would greatly appreciate assisstance !!!
ps: using the key manually doesnt unlocked the door.
Aug 13, 2011 | 11:57 PM
Super Moderator MY350Z.COM
Remove the engine undertray, reach to the top when the hood reliese is and pull the cable.
Aug 14, 2011 | 12:02 AM
Quote:
Originally Posted by
have you done this , did it work ?
Aug 14, 2011 | 12:09 AM
samnah
No, but others have.
Aug 14, 2011 | 12:10 AM
samnah
obviously if he suggested it he probably has done and it's safe to assume it does work.
why ask if your situation is so urgent?
redundant.
Aug 14, 2011 | 12:11 AM
thank you , im gonna give that a shot
Aug 14, 2011 | 06:06 AM
Why won't the key unlock the door? Mine does. It feels like it's totally mechanical.
Aug 14, 2011 | 06:46 AM
winchman
+1, I don't drive my car in the winter so it stays in the garage, and that always worked to unlock my doors even without the battery connected.
Aug 14, 2011 | 07:58 AM
For some reason my key wont open my car either. The car was never in an accident either as to say doors/handles were replaced.
Aug 14, 2011 | 10:15 AM
I wonder if its because of the sensor in the key?
Aug 14, 2011 | 10:33 AM
The RF chip in the key doesn't have anything to do with the locks in the door.
Aug 14, 2011 | 11:13 AM
Al Kapwned
exactly, hence why i carry a spare key in my wallet without a chip. it can unlock the door and crank the car, just wont start it. good for when you lock your keys inside.
Aug 14, 2011 | 11:31 AM
Duckeee
Best thing I EVA got from AAA.
Why won't the key work??? I no understand
Aug 14, 2011 | 01:15 PM
never heard of somthing like this maybe u should try turning said key harder or try different key in the lock sometime if its a newer key it might not like the lock
Aug 14, 2011 | 01:23 PM
I have a flip key taped to my library card in my wallet in case of emergency.
Aug 14, 2011 | 01:51 PM
Problem solved
got the hood open , thanks to 'terrasmak' advice,i removed the underlay, nd pulled on the cable !!!!
btw , manually the key did not work, i have no idea y, but i turned it as much as i could...no response what so ever.
Aug 14, 2011 | 01:55 PM
thanks for the help everyone
Aug 14, 2011 | 11:54 PM
How about showing us exactly where you were able to pull the cable. It's got a jacket over the part that keeps you from getting to the wire inside. Do you just pull on the jacket up near the latch?
Siqcology
Sep 18, 2019 01:45 PM
Mattg350z
Oct 2, 2015 06:51 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
Mikey R6
Sep 19, 2015 01:48 AM
