I need help installing new C-West side skirts
Old Dec 17, 2003 | 08:29 PM
koolzero's Avatar
koolzero
Default I need help installing new C-West side skirts
I just got my C-West side skirts today and I took off my oem skirts. The oem skirts have little pop tabs but the c-west only has a few holes pre-drilled. My questions are:
1.) How would I go about making tabs similar to oem.
2.) Do I "really" need to use tabs or can I just use screws?
3.) Could I use 3M tape and screws instead?
Suggestions and advice appreciated!!
p.s. Local body shop was going to charge me for an hour of labor to take off the OEM skirts! It took me maybe 25 minutes and I've never taken side skirts off before and they supposedly have 10 years of experience!! What BS! It would probably take then half the time it took me.
Old Dec 17, 2003 | 09:07 PM
ether's Avatar
ether
did you get the instructions in English? I have the instructions and could provide some guidance if you got them in Japanese.. mine were installed per the instructions and no problems with them so far..
Old Dec 18, 2003 | 05:51 AM
Dubby's Avatar
Dubby
Guys can I get some pics of your rides with the cwest kit on it...cuz I'm thinking of getting the c-west n1 bodykit
Old Dec 18, 2003 | 06:16 AM
ether's Avatar
ether
Dubby, check out this thread i posted some pics there. https://my350z.com/forum/showthread....threadid=52263
Old Dec 18, 2003 | 10:05 AM
koolzero's Avatar
koolzero
I didn't get ANY directions with my side skirts. Please give me any directions that you have. Thank you!
Old Dec 18, 2003 | 10:54 AM
hfm's Avatar
hfm
If you're talking about the white tab that is afixed to the OEM skirt, you can do without it. It would be a pain to fabricate. Btw, those tabs will snap off when you remove the skirt if you're not careful.
There are so many bolts, it's not going to make much difference but perhaps you can use the tabs that came with the OEM skirt.
If you're talking about the black pop tabs, use the OEM bpts when installing the CWest. Took me 20 minutes how to stick those suckers in properly. Duh!
Old Dec 18, 2003 | 01:58 PM
koolzero's Avatar
koolzero
Yeah I broke a few of the white ones taking off the oem. On the c-west skirts it has 2 holes drilled in the top portion close to the kick plates. Did you use bolts there or the black pop tabs?
Old Dec 18, 2003 | 02:00 PM
koolzero's Avatar
koolzero
Oh and what is the price you guys have paid to have them painted; that is if you didn't get carbon fiber. I sort of wish that I did now but a little bit more than I wanted to spend. Espically now sinced I just bought a Nismo wing...
Old Dec 18, 2003 | 02:03 PM
hfm's Avatar
hfm
The bpts are for the front fenderwells, 2 there, and I recall one or two in the rear. When you are putting them in, press the centerpiece in otherwise, it will be a pita to place them in the hole. The kick plate area uses bolts however, I recall the white tab was similar to the bpts.
Old Dec 18, 2003 | 02:20 PM
ether's Avatar
ether
here is pic of the instructions.. they are very basic only 1/3 of a page for the side skirts. its basically what other have said just use the screws..
Old Dec 18, 2003 | 04:21 PM
koolzero's Avatar
koolzero
What kind and size of screws do they want you to use for the two closest to the kick plates?
BTW looks like a piece of cake.
Oh and I have to drill holes for those 2 screws correct?
Old Dec 18, 2003 | 05:14 PM
havabooz's Avatar
havabooz
unless it is evident that the side skirt will not hold on with the holes that are already drilled, then you dont really need to drill more holes..it will hold fine with that many holes and some 3m
Old Dec 18, 2003 | 07:42 PM
koolzero's Avatar
koolzero
it looks like i have to drill 2 holes to attach the top portion of the skirts. If I do that with 3m tape then it will be pretty solid. Where can I get some 3m tape, does Home Depot have it?
Old Dec 18, 2003 | 07:56 PM
koolzero's Avatar
koolzero
Man these looks sweet in black I should have gotten carbon fiber
I need to drill here. Instead of using a screw here I could probably use a bpt. What do you think?
Attached Thumbnails I need help installing new C-West side skirts-dsc00015.jpg
koolzero's Avatar
koolzero
And here
Attached Thumbnails I need help installing new C-West side skirts-dsc00016.jpg
Old Dec 18, 2003 | 07:57 PM
koolzero's Avatar
koolzero
Attached Thumbnails I need help installing new C-West side skirts-dsc00014.jpg
Old Dec 19, 2003 | 05:07 AM
Dubby's Avatar
Dubby
Ether...you car looks hot! very clean, the only thing is that its black and black cars make it hard to see the details of the kit...nevertheless I like it alot and the rims flow really well with the body what size r they and tire with too?
does anyone have a full cwest n1 body kit?
Old Dec 19, 2003 | 07:40 AM
koolzero's Avatar
koolzero
I do, minus the spoiler.
Old Dec 19, 2003 | 08:17 AM
havabooz's Avatar
havabooz
show some pics
Old Dec 19, 2003 | 08:31 AM
Dubby's Avatar
Dubby
can you post a pic up Koolzero? a nice clear pic, one that's not in the dark
