I'm in the same boat. Only about an inch drop, but still scrape on any driveways that are at all steeper than average...
Do you have a problem in parking garage's? My Z stays far far away from them... The incline will decimate the lip. I don't know how these HellaFlush guys do it on the daily.
Most garages around here are alright. The one on campus is brutal though.
Originally Posted by BoomerZ33
you need some wood planks bro (half inch, 1 unch, 1.5 inch). that's how i get around without scraping...too much.
You drive around with 2x4's in the car and throw 'em down when you need to get in places? That's gangsta!
I've never needed to get into a driveway that bad...
Originally Posted by TehkMob
I scrape/lay frame on the daily, it's part of being low.. F'k it, just a car...
Rather not destroy it though, I generally just try to be proactive in my approach to steep stuff.
I have to park in a STEEP parking garage at work.
You get use to it. I sure did, after working 5 days a week
You gotta get the angles right!!
Originally Posted by Flo-ridaZ33
I'm at that ride height with the same lip... It's plenty low, I hit most everything.
+1 I'm probably at the same ride height.
Low enough to close the tire gap.
But high enough to drive around.
Originally Posted by sry110
I really like the way this car turned out. It looks classy and aggressive while maintaining driveability due to not being slammed down on the ground.
