Bi-xenon mod
Old Nov 22, 2011 | 12:16 PM
350RIDER's Avatar
350RIDER
Default Bi-xenon mod
Ok so I'm contemplating on doing the 06-08 conversion on my 04 z non hid model. Does anyone know what I will need to do if I wanted to convert the balast to work with my car? Also I want to know if I just buy the housing can I use an aftermarket hid setup instead of stock ballasts and bulbs?
Old Nov 22, 2011 | 01:23 PM
bmccann101's Avatar
bmccann101
its considerably more work when you didnt have HID in the first place, otherwise its plug and play.
As a guy who has a set of 2006 lights already fully apart in his kitchen right now..... theres two ways to answer your question about OEM vs aftermarket HID parts. One is yes, the other is no. becuase theres alot of issues youl have w out going OEM.
HID aftermarket possible? Sure.. but youd have to modify some things. All the internals would likely be stripped off the back of the headlights if you bought the bare bones versions. Most aftermarket HID harnesses will fit under that bulb cap.. which you may or may not get.... and the new ballast itself will ahve to go inside the area left by the other missing ballast.. which presents you another problem.. while these lights are vented to the outside by a little rubber valve, they are predominantly sealed. That ballast ( OEM) is a bottom seal as well as a ballast. Its got a rubber seal all along it. W out it, youre open on the underside. Bad news.
I bought my headlights used at 269 each, and it took forever to find them, but your BEST bet with the LEAST headhache and modding and possibility for issues is to buy them complete.
Old Nov 22, 2011 | 02:34 PM
350RIDER's Avatar
350RIDER
Yea thats what I was thinking. But with complete ones what do I have to mod up.I kno the plugs are different
Old Nov 22, 2011 | 02:37 PM
bmccann101's Avatar
bmccann101
if you buy a complete OEM headlight w all the stuff on it, its a plug and play. No modification.
Old Nov 22, 2011 | 02:51 PM
350RIDER's Avatar
350RIDER
I have a base model though.
Old Nov 22, 2011 | 03:42 PM
Guilty1s's Avatar
Guilty1s
its pretty easy to rewire them... im about to have to do it again... got new headlights. PM me if you end up getting them as my new ones are on the way.
Old Nov 22, 2011 | 03:43 PM
KornerCarver's Avatar
KornerCarver
Here is a link to instructions to put the HID headlights in the base models. I can't put in the link correctly, so just replace the XXX with *********.
http://www.xxx.com/wiki/index.php/Ba...Headlight_Swap
I also can't put in the name of the other site so try this without spaces 3 5 0 Z - t e c h
Old Nov 23, 2011 | 08:22 AM
bmccann101's Avatar
bmccann101
ah yes, the magic of google.
ANyways OP, thats it mang.. basic wiring that can be done in an hour. Just make sure you do it right, ie solder the wiring and use heat shrink etc. Dont use crimp connectors and crap like that.. or you will have issues within 24 months.
Old Nov 23, 2011 | 02:03 PM
350RIDER's Avatar
350RIDER
Yea I just bought the one retiple718 was selling. Gotta take them apart and have my boys do some work on them to get them back to tip top shape.
Also after looking at that site looks like I need to get the morano plug is that right?
Thanks fellas.
Old Nov 26, 2011 | 08:12 AM
epidemic007's Avatar
epidemic007
Thanks fellas.
i was gonna buy those, def a good deal u got on em. too bad somethings came up. good luck bro
Old Dec 5, 2011 | 09:08 PM
350RIDER's Avatar
350RIDER
Just got my sti lenses and halo LEDs about to bake these bitche$
Stevo Z
Oct 3, 2015 09:14 PM
Dymsi
Sep 29, 2015 11:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
