How to make trunk pop up open without lifting it?
Old Nov 24, 2011 | 07:59 PM
abdulla16's Avatar
abdulla16
Default How to make trunk pop up open without lifting it?
I have a basic 350z with a lip spoiler that I installed. Currently, I have to pull the trunk up and press the trunk release button for the trunk to open. I know that I need new trunk struts. The question is: which trunk strut should I use? the one for cars with or without spoiler?
Another question that I have is: If I buy a strut with higher pressure will the trunk fully open without lifting it? Thanks for your help!
Old Nov 24, 2011 | 08:06 PM
mr. sparco's Avatar
mr. sparco
Look up the penny or quarter mod. The struts help lift it up, there are springs that pop it open.
Old Nov 24, 2011 | 11:57 PM
dmroberson's Avatar
dmroberson
I had this same problem... my OEM shocks were finally done... and I have a lip spoiler as well. I upgraded to the UHP struts from Z1 Motorsports, and the problem is solved.
Here's the thread where they're selling them.
https://my350z.com/forum/body-exteri...ch-struts.html
Will not fully open, but will pop enough for the latch to not catch it.
Old Nov 25, 2011 | 12:41 AM
R350Zz33's Avatar
R350Zz33
is the weight out ?
Old Nov 25, 2011 | 03:14 AM
JCITY's Avatar
JCITY
Common problem...
Replace your deck lifts/struts with some heavy duty ones.
As another post mentioned,Z1 MOTORSPORTS.COM has the best struts available at the best price &service.I have a set of heavy duty(made for wings/spolers) and my rear deck pops right up!
Old Nov 25, 2011 | 10:10 AM
ocdz's Avatar
ocdz
+1 on the penny mod. best 8 cents I ever spent on my car.
Old Nov 26, 2011 | 11:33 AM
JCITY's Avatar
JCITY
Cool a bandaid..
Yeah,it works.But,will not work forever.
How long have you had the pennies in there?
Also,caution...use too many as a shim,you will
have a nice protrusion on the surface from the rod
inside the spring lift.
Old Nov 26, 2011 | 03:17 PM
122554's Avatar
122554
Bought mine from partsavenue on ebay for $54.00. Complete kit, couldn't be happier with them.
Old Nov 26, 2011 | 04:13 PM
ocdz's Avatar
ocdz
2 years, and no problems yet. although I only open the hatch about 5 times a year.
Old Nov 26, 2011 | 04:17 PM
terrasmak's Avatar
Get the HD struts, find someone who also needs them and buy a pair. Only install one per vehicle, with both installed you can launch small kids from the hatch. Single strut installed and t held my Nismo V1 wing no problem and still hold my APR wing no problem.
Old Nov 28, 2011 | 05:20 PM
beezee's Avatar
beezee
Eitherway you will have to lift it to fully open as long as you have the stock hatch. I have the Z1 heavy duty struts. You lift up to some point and then it goes up by itself.
And to close you have to pull it down harder than you would if you had stock struts
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
