HID install help
Old Dec 23, 2003 | 05:27 AM
TriX's Avatar
TriX
Default HID install help
I bought and HID kit from zred. But it appears he will be pretty busy.
does anyone know any shops in FL (miami, pembroke pines, ft lauderdale area) that would do the install?
i have no instructions and don't want to mess with it. if anyone has input. i would appreciate it.
Old Dec 23, 2003 | 08:40 AM
Jun's Avatar
Jun
i bought a kit from Zred as well, i have a set of instructions that you could use, it is pretty straight forward, i installed it myself.
Old Dec 23, 2003 | 08:42 AM
MY350Z.COM's Avatar
Default Re: HID install help
This may be of some help.....or not
https://my350z.com/forum/showthread....threadid=52790
Old Dec 23, 2003 | 03:48 PM
TriX's Avatar
TriX
thanks.
Old Dec 23, 2003 | 04:28 PM
devildoc's Avatar
devildoc
pm me your email address, I've got some instructions that zred made up for me. I'll be more than happy to email them to you.
Ian
Old Dec 23, 2003 | 06:52 PM
Jun's Avatar
Jun
Ian
those are the same ones that i have (zred gave them to me) !
Old Dec 25, 2003 | 02:44 PM
TriX's Avatar
TriX
devildoc: i sent you a pm
jun: i will probably have some more questions for you. i'll look over the instructions and see. i was told the install takes about 2 hrs. which doesn't sound bad at all.
Old Dec 28, 2003 | 11:48 AM
Jun's Avatar
Jun
The installation is pretty easy. If you have never done it before, you have to remove the bumper and then remove the headlights. Removing them are not hard, i can probably remove the bumper now in less than 10 minutes, it's only the first time that you are really careful to make sure you don't break anything. If you need help let me know.
The only part that you are going to take long is sealing the hole that you have to make for the wire to go through the headlight because you have to let the silicone dry. I made a hole in the grey plastic cover that covers the headlight in the back, about 1.5" big, i was looking for a rubber grommet to seal it so that it would be easier to seal with the silicone, but couldn't find one. i kinda rigged it using the leftover plastic circle i cut off and sealing around that, not the best, but this is temporarily until i find the rubber piece i'm looking for.
Pleask
Dec 21, 2021 03:17 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
