Those with this spoiler...
I just received this spoiler. But the problem is installing the spoiler. No instruction but rather a couple of half and inch of bolts.
Does this spoiler require the same equipment used to install the oem spoiler or can I use the double sided 3m tape? I have the oem spoiler on but its on double 3m sided tape, no drills.
The OEM is lighter compared to that. I think that's what they're comparing it to. My Nismo V3 is pretty heavy and HD hatch shocks can't get it off the locking assembly when I unlock the hatch. I believe a true INGS has both tape and bolted mounting locations. Double sided tape works well with smaller spoilers ie Blitz, OEM(the use mounting bolts btw), and roof wings. I'd bolt it down... Double sided tape would work but I wouldn't say it's the correct why of doing it.
The spoiler does come with bolts but they look small in my opinion. Plus, since I have the oem spoiler installation equipment, came late so I install the oem with tape, can I use the oem spoiler installation equipment on to the ing spoiler or does it require a different installation equipement?
I did also used the two stock mounting bolt holes and double sided tape it also.
I got the shocks from here
http://www.350zhatchshocksandmore.com/index.html
This is were I got mine.
http://www.drivenbystyle.com/2003-20...-p-279925.html
I hope this helps.
Huyrua, did yours have studs rather than bolting from the inside up into the spoiler? How many do you have?
OP if it has bolts there has to be stud in the wing and the screws look to be self tapping.
Compare to the oem spoiler, we can use the nut for the bolt like this
